Flooring Suggestions For Basement Bathroom - Flooring - DIY Chatroom Home Improvement Forum
Old 09-03-2009, 09:38 AM   #1
Rewards Points: 174
Flooring suggestions for basement bathroom
I put down a Dricore subfloor in my basement. The living area will have carpet but I am not sure what to put down in the bathroom. I wish I could put tile but that is a no go with Dricore. I know that I can use vinyl, laminate or engineered wood but I am not sure which will be the best application for an area that will eventually get wet (I have 3 kids).
Any ideas or experiences? Thanks.
Leoskee is offline   Reply With Quote
Old 09-03-2009, 06:38 PM   #2
For what you describe, I would pick vinyl. Inexpensive, easy to install, cheap enough to replace often if you don't like it, waterproof if properly installed.
Old 09-03-2009, 08:53 PM   #3
Rewards Points: 174
Can you explain "properly installed"? Thanks.
Old 09-05-2009, 04:53 PM   #4
We just did a very large garage area, about 500 square feet with this Konecto vinyl flooring, I've been in the flooring business since 1980 and this is one nice floor, not only the quality, but the ease of installation. To be quite frank, there is no need hire a guy like me, anyone can install this floor. You simply press the planks together and your done. It's flexible, waterproof and you don't need to mess with glue. We bought it from fastfloors.com on this page
Konetco Flooring
I am currently working with two other clients that want to use the same thing. You can also use laminate flooring however in my opinion this looks nicer, is easier to install, easier to maintain and much more durable. Hope that helps.
flooringdoctor is offline   Reply With Quote
Old 09-05-2009, 04:58 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Its over Dri-core!!! Do you know what Dri-core is Doc? I doubt you would want that product over Dri-core.
XXX
Old 09-05-2009, 05:03 PM   #6
Bud, yes I know what the Dricore is and no idea why you couldn't use the Konetco over the Dricore. The Konetco floats like laminate, it doesn't get glued down.
Old 09-05-2009, 08:18 PM   #7
Rewards Points: 174
Im not familiar with the product. Is it just a laminate floor?
Old 09-05-2009, 09:06 PM   #8
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 52
There are several long threads on here concerning Konecto.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 09-06-2009, 12:41 AM   #9
Rewards Points: 174
Okay. Can you just give me the jist of the threads?
Old 09-06-2009, 02:14 AM   #10
Rewards Points: 52
Probably 50/50. Some people like it, some hate it. The people who have had problems say they don't get a good response from Metroflor.
Old 09-06-2009, 09:13 AM   #11
Konecto
The dealer I buy it through has sold a ton of it and I am not aware of any major issues. I installed it and it seemed very easy and straight forward. Here's a link to their installation guide as a reference Konecto install
In short it's a higher end vinyl along the lines of a Nafco type product only you simply press the planks together at the joints, no glue.
Old 09-06-2009, 10:30 AM   #12
Rewards Points: 52
And if you are lucky, it stays together.
Old 09-06-2009, 11:40 AM   #13
Tileguy
Bud Cline's Avatar
Rewards Points: 558
.......and there ya go, we have a winner.
Now take a look at how the Dri-core product assembles. OK OK OK, I'll spell it out for the inexperienced that just don't have a clue.
The Dri-core can have roaming issues over time. The 'wish and stick' laminate can't stay together under such circumstances. You just as well be using it in your garden.
XXX
Old 09-06-2009, 11:57 AM   #14
Well by no means am I claiming to be a expert on Dricore but if the sub-floor being the Dircore has this tendency to roam as Bud states it does, and you the customer feel there may be concerns with the Konecto holding together because of this roaming, then I'd suggest simply contacting Metroflor to see what they say. They have a customer support location in Boca Raton, FL here's the toll free number 866-687-6357
Old 09-06-2009, 12:12 PM   #15
Rewards Points: 52
Better yet, go read the threads and see what kind of response customers recieved after they installed the product. That is the true measure of a company.
bathroom flooring carebear560 Flooring 9 07-24-2012 08:12 PM
Bathroom Flooring? Whole House Flooring? leezarrd Flooring 9 02-08-2012 02:47 PM
Bathroom Flooring bbrown92y Flooring 10 05-27-2008 11:49 AM
Flooring for both bedroom & bathroom that's pet friendly? larcd Flooring 10 12-30-2007 11:58 PM
Chlorine Resistant Flooring for Bathroom herbolaryo Flooring 7 05-22-2007 10:05 PM
