#1 |
flooring replacement
700 sqft of carpeting equals how much laminate flooring
#2 |
700 sq ft? Do you mean how much is the cost, how many boxes? Because the boxes have a square footage of coverage listed
#3 |
700 sq ft.
is this a trick question? if you go buy some of the guidelines you would buy 15% more for waste. iv'e never wasted more then 1 or 2 % installing laminate. always start the next row with your cutoff from the previous row if it is long enough and is far enough from the closest joint. did 800 sq feet of engineered cherry and had about a five gallon bucket of scrap left. Last edited by DannyT; 11-15-2012 at 03:03 PM. |
| Display Modes | |
| Need advice refinishing old flooring and blending with new unfinished flooring | Daemian Raj | Flooring | 2 | 09-26-2012 09:46 PM |
| Installing Hardwood Flooring on Concrete Flooring, Condo | slickwilly789 | Flooring | 1 | 10-08-2010 09:53 PM |
| Installing engineered flooring in the Philippines | Flt_Simulation | Flooring | 15 | 07-21-2009 09:00 PM |
| Basement flooring options.. | Tommy2 | Flooring | 9 | 02-14-2009 08:06 PM |
| no glue, no nails wood flooring - little help? | reds_21 | Flooring | 2 | 02-13-2009 12:32 PM |
