Flooring Problems - Flooring - DIY Chatroom Home Improvement Forum
Old 01-23-2009, 11:31 PM   #1
Flooring problems
Hello, I had a contractor add an addition to my house, he put down a 3/4 osb floor over the rafters, now he wants to put down the carpet, I have been told by friends, that he needs to put a floor over that with a moisture barrier. Is this true? Any help would really be appreciated. Thank you
indianmedic is offline   Reply With Quote
Old 01-24-2009, 08:20 AM   #2
Still Learning
Carpet with a moisture barrier? New one on me. More details on why?
HardwoodGuy is offline   Reply With Quote
Old 01-24-2009, 09:47 AM   #3
Tileguy
JazMan's Avatar
Rewards Points: 388
There is no reason to apply anything on the OSB to install carpeting. If your house has a crawl space any moisture barrier should be install on it's floor per local standards. Otherwise if you have a basement, nothing is required or recommended.
Jaz
Old 01-25-2009, 07:46 AM   #4
Rewards Points: 150
Are your friends contractors?
Unfortunately friends, while the intention is good, offer advice based on different circumstances.
If you were doing anything other than carpet I would say maybe they are right depending on the conditions.
If your contractor has done everything else right , I would defer to his advice rather than your buddy the accountant
mike costello is offline   Reply With Quote
flooring rot and problems patrick.schantz Remodeling 5 09-13-2008 08:51 PM
Slate Flooring...Problems Encountered djchrishart Flooring 1 12-12-2007 11:13 AM
8 month old modular with flooring problems?? HELP!! SomewhereInNC Flooring 1 07-27-2006 01:46 AM
8 month old modular with flooring problems?? HELP!! SomewhereInNC Building & Construction 2 07-26-2006 11:11 PM
