Flooring Over MDF? - Flooring - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By tomottoe
  • 1 Post By stick\shift
Old 01-06-2017, 02:18 PM   #1
Rewards Points: 4
Flooring over MDF?
Hi
Iím planning to install some 2 1/2 inch prefinished red oak (tongue in groove) flooring. The room is 16x18; the sub floor is MDF. I thought I remembered reading MDF wasnít a great surface for attaching floors toóit doesnít have the holding power that plywood does. But my carpenter says because itís tongue in groove, as long as I make sure the MDF is screwed down really well to the joists, I donít have to worry about the floor install.
Does this sound right?
thx
tom
tomottoe is offline   Reply With Quote
Old 01-06-2017, 02:20 PM   #2
Rewards Points: 348
Re: Flooring over MDF?
Never heard of T&G MDF flooring. Are you sure about this?
stick\shift is offline   Reply With Quote
Old 01-06-2017, 02:40 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 212
No it does not, especially for the reason he gave you. Carpenter huh? Ax him what t&g has to do with how well a fastener holds into the sheet?
MDF is not used for flooring, as far as I know, maybe you mean particle board. PT, was used in the '80's etc. by builders who wanted to cut corners, it's junk for floors.
I know of no flooring manufacturer that wants their flooring anywhere close to particle board, no matter as a subfloor or underlayment. A subfloor/underlayment should be either plywood or OSB of the proper grade for the purpose.
When was your house built, where is it?
Jaz
Old 01-06-2017, 03:03 PM   #4
Rewards Points: 4
Hi Jaz
I'm in southern CT. House was built in '67; yes, you're right, particle board is what I meant. Room originally had wall to wall carpet which we've pulled up.
Sounds like I'll need to swap in plywood for subfloor. Thanks for the advice.
tom
JazMan likes this.
Old 01-06-2017, 03:46 PM   #5
Rewards Points: 348
Particle board has to go.
*Microphone drop*
JazMan likes this.
Old 01-06-2017, 05:58 PM   #6
Rewards Points: 12,794
I'm going to make a guess, homes I've work on in that time period only had a 1/2" plywood subfloor then they laid 3/4 particle board over it.
Makes 0 since to me, but that's just how it was done long ago.
If it was mine I'd be removing what's there and installing Advantech T & G over it.
Lifetime warranty, no voids, great nail holding power, nothing to delaminate, cheaper.
removing laminate flooring mikeinMemphis Flooring 24 02-24-2013 10:06 PM
Flooring for hot tub room with tongue and groove base flooring. tkmiller Flooring 0 10-24-2010 01:21 PM
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 09:53 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 09:00 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 12:32 PM
