Old 06-05-2011, 11:35 AM   #1
Flooring options in lower floor bonus room
Hi All:
Just wondering what the pros here suggest for flooring options in a downstairs bonus room, which is adjacent to the garage. The challenge I have is that the room is also where the washer/dryer are located but it's large enough to be a play room for our one year old daughter. My initial thought was to lay tile on the portion of the room where the washer/dryer is and then just carpet the rest but I'm not so sure I like the look. I don't reallllllly like the idea of an engineered hardwood but that though crossed my mind too. Any suggestions? The subfloor is the concrete slab. Thanks!
Trustmemalawyer is offline   Reply With Quote
Old 06-05-2011, 11:43 AM   #2
One more thing to add. The room has exterior access to the backyard so the flooring needs to be durable/easy to clean as there will probably be a decent amount of traffic there.
Old 06-05-2011, 03:18 PM   #3
Tileguy
Bud Cline's Avatar
Are you sure you spelled your "User Name" correctly?
Old 06-05-2011, 03:31 PM   #4
There are a limited number of characters one can use for a username. So yes, I know it's not spelled correctly. Got a suggestion for some flooring?
Old 06-05-2011, 03:45 PM   #5
Super Moderator
Ceramic tile is the natural choice ---not damaged by water--can take dirt and grit--
Add a nice thick rug for your young one----done----
oh'mike is online now   Reply With Quote
Old 06-05-2011, 06:30 PM   #6
Tileguy
Bud Cline's Avatar
How about: "Trusmeimalawyer"?
Oh Yow That! How about ceramic tile it is the natural choice and not damaged by water. It can also take dirt and grit.
Old 06-05-2011, 07:38 PM   #7
Super Moderator
Add a nice thick rug for the young one.
Old 06-06-2011, 09:04 AM   #8
Tileguy
Bud Cline's Avatar
Old 06-07-2011, 10:58 PM   #9
Maybe consider acid staining the concrete. Has a very nice look similar to expensive stone. It can even be scored with a tile pattern. All this can be done for less than the cost of most flooring materials and installation labor.
RhodesHardwood is offline   Reply With Quote
The Following User Says Thank You to RhodesHardwood For This Useful Post:
oh'mike (06-08-2011)
Old 06-08-2011, 12:53 PM   #10
Thanks for the recommendations everyone. After doing some further research, I think it makes the most sense for us to install tile. I had a chance to pull up the old carpet yesterday and noticed two things: 1) old vinyl tile and 2) that, at least around the perimeter of the room, there is some moisture seepage. The house was built in the 50s and so there is no drainage system around the house (something I will address down the line at some point).
Whatever the case, I was hoping to get some advice/tips on how to prepare the floor. Of course, I will remove the tile and try and clean as much of the adhesive off as possible. The floor is slightly of level and though I will try and level it out a bit with the thin set, I think its something I am okay living with since it’s the basement. I have read varying opinions about how to prepare the floor, i.e. cement board, plastic vapor barrier etc. What do you all suggest? Since this will be a playroom, I would like to keep the room/flooring as warm as possible but I know my options are limited, as this IS ceramic tile flooring and it IS the basement but I would like to limit it as much as possible.
Thanks in advance!
Old 06-08-2011, 01:44 PM   #11
Pro Flooring Installer
rusty baker's Avatar
I guess you realize that it's possible that the old vinyl tile and adhesive contain asbestos. You haven't said how old it is. VAT was common until the 90's.
http://www.asbestoshistory.net/asbestos-tile.html
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 06-08-2011, 02:27 PM   #12
Yes. I'm having a company come check it out and if it's asbestos containing, well have it removed accordingly.
No glue vinyl flooring in a wide room? BizeeB Flooring 1 11-23-2010 09:50 AM
Flooring Options imanerd Flooring 12 04-15-2010 09:30 AM
Hardwood flooring - 3 walls and a sunken living room basledder Flooring 1 12-09-2007 06:34 PM
Laminate Flooring Flowing from Room to Room frskelly Flooring 1 09-16-2007 12:14 AM
Flooring Options yankee009 Flooring 2 08-16-2006 12:39 AM
