Flooring Options For A Childrens' Home Dining Hall - Flooring - DIY Chatroom Home Improvement Forum
Old 04-02-2011, 10:31 PM   #1
A Little Of Everything
Rewards Points: 1,364
Flooring Options for a Childrens' Home Dining Hall
Some time this summer a Church Men's Group I'm part of will be installing a new floor in the Dining Hall of a Children's Home. We'll be removing the old destroyed linoleum and replacing it with something.
We'll be going over good, solid, smooth, level concrete.
What flooring material should we use? Here are some of my initial "pros and cons" thoughts.
1. Ceramic or Porcelain Tile. Highly durable (much needed), and could look great. But it would also feel cold, could be slippery, and would break anything dropped on it.
2. Linoleum. Fairly easy install, and overall good durability. But the floor is larger than 12', and the present linoleum split badly at the seam.
3. Wood Laminate. The obvious negative would be durability. This is a high traffic area. However, it would be a very easy install, and we could go into it with the assumption that, in a couple years when the stuff is worn out, we'll just replace it. I've seen some good 8mil laminate on sale for as little as 75 cents per square foot, so the price could be very attractive.
What are your thoughts? Again, this is a high traffic area - roughly 16' x 25'.
Thanks!
DrHicks is offline   Reply With Quote
Old 04-02-2011, 10:57 PM   #2
Rewards Points: 756
Durability and things breaking go hand in hand.
I have two options.
1. How about just leaving the concrete exposed. You could finish the floor with that Epoxy paint and even sprinkle in the flakes to take away the industrial look.
2. Rubber. You can find this in some commercial kitchens. It's easy on the feet.
AandPDan is offline   Reply With Quote
Old 04-02-2011, 11:01 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 82
Bare concrete would make me nervous with small children. I agree with the rubber.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 04-03-2011, 08:35 AM   #4
Buying the first round
LIHR's Avatar
"Children's Home" "Dining Hall" "high traffic area"
Seems to me those are the factors that should steer you to a very durable, long service life, easy to clean, non-slip surface.
Commercial grade round dot flooring
http://www.ranteso.com/
LIHR is offline   Reply With Quote
Old 04-03-2011, 02:38 PM   #5
Rewards Points: 5,336
Laminate floors come in 5 grades. From low traffic residential to commercial.
Check out this link:
http://www.ehow.com/about_5542028_ty...-flooring.html
Ron
Old 04-03-2011, 02:43 PM   #6
Rewards Points: 82
Why not VCT? Not a hard DIY project.
Old 04-03-2011, 03:20 PM   #7
Whoa - suddenly that seems like a smart option!
Is there any difference between VCT and the old Asphalt Tiles?
Old 04-03-2011, 03:42 PM   #8
Rewards Points: 82
VCT (vinyl composition tile) is easier to work with and don't contain asbestos.
Old 04-03-2011, 04:02 PM   #9
Gotcha. That's what I was wondering. Thanks!
The VCT (I guess I still called it Asphalt or Commercial Tile) that I installed in a rental house kitchen, a couple years ago, was not as brittle as I remember the older stuff being.
Hey - is there any adhesive for VCT that does not require you to sit & wait half-hour to an hour, before installing the tiles?
Old 04-03-2011, 04:12 PM   #10
Rewards Points: 82
No, that is the proper way to install it.
Old 04-04-2011, 08:15 AM   #11
Dang. I was hoping for something really, really easy.
Thanks for the advice man, I appreciate it!
Old 08-31-2011, 11:11 AM   #12
Thought I'd let you guys see how things turned out.
We pulled up the old crappy linoleum (that had been flagged by the inspector) and replaced it with VCT. It turned out great.
Several of the resident boys got to help, so they believe THEY did it - which is great. Everyone is happy.
Thanks for all the help and advice!
Out with the old:
In with the new:
Old 08-31-2011, 11:19 AM   #13
Rewards Points: 756
Looks good! Nice job and I'm glad the kids were involved. It'll give them a sense of "ownership" and pride.
Old 08-31-2011, 01:07 PM   #14
That is exactly what happened, and it's fantastic! 3 of the resident boys were there every step of the way. Our point man showed them how to lay the tile in the right direction, and right side up, and the boys actually did a great job.
As you know, in their minds, THEY laid the floor - which is just as it should be.
The Following 2 Users Say Thank You to DrHicks For This Useful Post:
AandPDan (08-31-2011), rusty baker (08-31-2011)
Thoughts and opinions on "Trafficmaster Allure" flooring from Home Depot? zel Flooring 849 07-28-2015 12:31 AM
Flooring options over asbestos tiles clouds88 Flooring 1 07-16-2008 04:52 PM
Basement Flooring for Home Gym DIYamateur Flooring 10 02-05-2007 08:59 PM
Flooring Options yankee009 Flooring 2 08-15-2006 11:39 PM
modular home flooring problem wen Flooring 1 08-15-2005 01:11 PM
