Flooring Novice - Flooring - DIY Chatroom Home Improvement Forum
Old 12-17-2009, 11:40 AM   #1
kpt
Post
flooring novice
Greetings,
with regards to the flooring dilemma to my walkout basement (600 Sq ft) i am inclining towards engineered hardwood (rather than laminate). Would really appreciate any advice or comments for my choice.
Also would like to know of any solutions for doing engineered hardwood for the staircase
I am a novice DIY 'er and would like to do it myself.
Advance thanks to any suggestions
kpt is offline   Reply With Quote
Old 12-17-2009, 12:31 PM   #2
Remodeling Contractor
This is the better choice. For stairs some manufacturers will carry the nosing and pieces for the stairs to match, so just select the right one and you are all set to go. Be sure to verify that you have no moisture issues to deal with. Visual inspection means nothing. Use a test kit or at least tape a square of plastic to the floor and inspect it the next day.
Old 12-20-2009, 12:51 PM   #3
kpt
Smile
thanks for the reply
Today buying laminate instead of en hardwood. looked more appealing.
found (@ home depot) special oak with nose and riser for stairs. 35 $ for 42 " for one .only thing is i got to cut and stain to my floor (walnut).i will post my progress.
Suggestions and ideas are welcome and appreciated always
thanks
KPT
Old 12-21-2009, 11:40 PM   #4
Moisture Test
Assuming that it is bare concrete you can place a glass cup in each corner, upside down....
Leave for a day or two. Then come back, if moisture has developed in glass, you have a problem...
JGibbsRemodel is offline   Reply With Quote
Strange engineered wood flooring install in Philippines (pics) Flt_Simulation Flooring 7 10-05-2009 09:00 AM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 11:32 AM
