Flooring Newbie - Flooring - DIY Chatroom Home Improvement Forum
Old 12-28-2010, 02:40 PM   #1
Flooring Newbie
Hi guys! Just bought a condo and I want to put in new flooring. I've been checking out iFloor.com and these two caught my eye:
http://www.ifloor.com/Bamboo-Floorin...es/IF-CS440276
http://www.ifloor.com/Hardwood-Floor...al/IF-TS439724
Questions:
1) Any opinions on iFloor.com? Any recommendations on any other retailers I should check out?
2) Any opinions on those two brands (links above) from iFloor.com? What other brands should I check out? Price is also a factor, trying to keep it under $3 a square foot.
3) Anything else I should look out for or pit falls I should to avoid?
4) Where should I buy the other accessories (baseboards/underlayments/moldings/etc.) for the installation?
I'm a super newbie and have no clue where to start. Any feed back is highly appreciated. I'm in the LA area too. Thanks!
condowner is offline   Reply With Quote
Old 12-28-2010, 04:25 PM   #2
Exciting!
I think both options would work for your particular application.
I just re-did my floors (1st timer fyi) and they turned out perfect. I took out the tile, resurfaced the floor and added a buttload (17-20 bags) of self leveling concrete (forgot the brand but it was about $30/bag) just to get it level.
You will maybe hear about getting your floor "flat" instead of worrying about getting it "level" - I personally subscribe to both philosophies b/c I didn't want people walking sideways in my dining room.
Good luck and make sure you budget time beforehand. I had to go back and forth to Home Depot a gazillion times for supplies so be sure to plan ahead of time.
idlewatcher is offline   Reply With Quote
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 4 06-07-2017 06:24 PM
Newbie to Flooring... Help! kalaniwavo Flooring 2 03-20-2011 04:44 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
Newbie w/a flooring question Laminate v. engineered wood UNCgal91 Flooring 2 08-25-2008 07:29 PM
Laminate Flooring - Newbie Trishl Flooring 9 04-21-2006 11:20 PM
