Flooring Nailer - Flooring - DIY Chatroom Home Improvement Forum
Old 12-06-2011, 08:07 PM   #1
JCG
flooring nailer
Will something like a Bostich MFN200, designed for 3/4-in flooring, work for 1-in flooring?
JCG is offline   Reply With Quote
Old 12-07-2011, 02:50 PM   #2
Rewards Points: 272
Flooring guns are designed with an exchangeable pad. If you have 1/2 inch flooring you use the appropriate pad. Depending on the gun being used you may be able to simply change the pad on it. If you are still uncertain, check with the manufacturer for confirmation. If all else fails, do a test on a piece to find out if you have enough penetration. My thoughts are that you should if you are using a 2 inch nails, but some warranties require you to use staples.
fixrite is offline   Reply With Quote
Old 12-07-2011, 02:59 PM   #3
JCG
Thanks. The Porta-Nailer Pro 410 model seems to make a pad for 1-in flooring. Only thing is, the nailer is rather expensive. I only need to do two rooms. I wonder if there's a cheaper model out there.
Old 12-07-2011, 03:24 PM   #4
Rewards Points: 272
what about rentals?
Old 12-07-2011, 04:41 PM   #5
Experienced
Jackofall1's Avatar
This is the one purchased so far put about 10K staples through it without a problem.
http://www.ebay.com/itm/RAMSOND-RMM4...item2a01b1bb6d
Mark
Old 12-07-2011, 05:40 PM   #6
DIY staff
Rewards Points: 7,174
I picked up a Harbor Freight gun---marked way down ---installed 650 feet ---nice gun--
Old 12-07-2011, 06:02 PM   #7
Rewards Points: 272
You could even purchase a used one from a rental store and then sell it when you are done using it. Just a thought.
The Following User Says Thank You to fixrite For This Useful Post:
oh'mike (12-07-2011)
Tags
flooring , nailer
Lumber Liquidators Bud Cline Flooring 11 10-28-2011 02:00 PM
asbestos in our ripped up flooring?? 6fthook Flooring 16 07-29-2011 11:06 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
Installing Bamboo Flooring with Brad Nailer? aaks38 Flooring 3 11-04-2008 09:11 AM
Nailer for flooring mpt1123 Tools 2 07-08-2008 12:24 PM
