-   -   flooring nailer (http://www.diychatroom.com/f5/flooring-nailer-125828/)
JCG 12-06-2011 08:07 PM
flooring nailer
Will something like a Bostich MFN200, designed for 3/4-in flooring, work for 1-in flooring?
fixrite 12-07-2011 02:50 PM
Flooring guns are designed with an exchangeable pad. If you have 1/2 inch flooring you use the appropriate pad. Depending on the gun being used you may be able to simply change the pad on it. If you are still uncertain, check with the manufacturer for confirmation. If all else fails, do a test on a piece to find out if you have enough penetration. My thoughts are that you should if you are using a 2 inch nails, but some warranties require you to use staples.
JCG 12-07-2011 02:59 PM
Thanks. The Porta-Nailer Pro 410 model seems to make a pad for 1-in flooring. Only thing is, the nailer is rather expensive. I only need to do two rooms. I wonder if there's a cheaper model out there.
fixrite 12-07-2011 03:24 PM
what about rentals?
Jackofall1 12-07-2011 04:41 PM
This is the one purchased so far put about 10K staples through it without a problem.
http://www.ebay.com/itm/RAMSOND-RMM4...item2a01b1bb6d
Mark
oh'mike 12-07-2011 05:40 PM
I picked up a Harbor Freight gun---marked way down ---installed 650 feet ---nice gun--
fixrite 12-07-2011 06:02 PM
You could even purchase a used one from a rental store and then sell it when you are done using it. Just a thought.
