Flooring Leveling Project Help - Flooring - DIY Chatroom Home Improvement Forum
Old 03-11-2012, 09:43 AM   #1
Currently I am looking to level my floors in a small living room. There are radiators, plaster walls, and molding around the floor. I am looking for help on best practices and customs solutions for leveling the floors.
Here are a few pictures:
I removed the old and damaged floors already but had so issues with the radiators. What is the best way to deal with them? Have them removed? Sounds expensive.
The molding along the floor is out of level just like the floors. I assume that this has to be corrected along with the floors. I want to save them but it seems taking them out is risky and it's plaster and lath behind it. Plus I damaged it will trying to take it off in one piece.
Basically I would appreciate some help in what I should do or the proper process. Thanks in advance.
management is offline   Reply With Quote
Old 03-11-2012, 09:48 AM   #2
Rewards Points: 528
Unless the floor is over an inch out why level?
Just smooth out the floor with leveling compound and put the new floor down
In remodeling you will rarely find level, especially with old houses like what you seem to have.
framer52 is offline   Reply With Quote
Old 03-11-2012, 12:59 PM   #3
What type of flooring will you be using ?
kj6887 is offline   Reply With Quote
Old 03-11-2012, 07:29 PM   #4
Rewards Points: 242
Tell us how your floors are out of level. North / south, east / west...sagging or bulging in the middle, or are they wavy...maybe just some warped sub-floor boards.
How bad is the out of level condition?
Different solutions for different problems.
Ed911 is offline   Reply With Quote
Old 03-13-2012, 08:47 AM   #5
Don't WANNA do it myself
mnp13's Avatar
Rewards Points: 512
Eek! Don't take the baseboards off! Take off the shoe moulding, lay the new floor, put the shoe moulding back on around the edge. The "problem" with most old houses is they were built to last and don't appreciate being dismantled. You'll likely damage the walls and baseboards trying to get them off.
Like previously stated, unless the floor is WAY out of wack, just let it be. If the joists are sagging, adding the weight of leveling isn't going to make the issue better.
You're going to have to move the radiators to put the new floor in, you'll probably have to run new pipes or add on an extension since they will be up higher on the new floor
Michelle
Fixing the re-muddling one room at a time...
mnp13 is offline   Reply With Quote
Leveling Flake Board Sub Floor billfox Flooring 6 11-22-2011 10:08 PM
First Timer - Questions About Hardwood Flooring for Stairs sunshine54 Flooring 0 10-16-2011 10:44 PM
Anyone used a project manager instead of GC? pulpit Building & Construction 10 02-11-2011 10:08 AM
Konecto flooring LookoutRanch Flooring 23 03-08-2010 03:32 PM
Basement flooring options.. Tommy2 Flooring 9 02-14-2009 07:06 PM
