Flooring For Kitchen - Flooring - DIY Chatroom Home Improvement Forum
Old 05-08-2013, 07:12 PM   #1
Flooring for Kitchen
Is it okay to install hardwoods or bamboo flooring in a kitchen? We want to keep the flooring the same through our main level & we want to use bamboo.
odonopt is offline   Reply With Quote
Old 05-08-2013, 10:16 PM   #2
Rewards Points: 140
yes. but, just like anything else = there are pro's and cons.
Fix'n it is offline   Reply With Quote
Old 05-10-2013, 09:36 AM   #3
You can, but in spots like the kitchen and bathroom I wouldn't recommend it. If you spill something on it, it can get damaged easily...water can get through the cracks, it can get dented, etc.
markx83 is offline   Reply With Quote
Old 05-11-2013, 04:16 PM   #4
We did.
We put bamboo in our kitchen almost a year ago (carbonized strand) and it is holding up really well.
Moritasgus is offline   Reply With Quote
Old 05-11-2013, 05:07 PM   #5
Retired & Not Likin' It
Jim McClain's Avatar
I've installed hardwood flooring in many kitchens. Yes, you do need to take extra care, but it's worth the trouble, in my opinion. You can use strategically placed area rugs in places that may be more susceptible to wear and tear. I kept one in front of the sink/dishwasher and even had a small rug where the dog ate. You can find rugs to protect your hardwood that will suit your needs and decor. About the only flooring that won't dent or damage from dropped objects is ceramic/stone flooring. Keeping the bamboo throughout will make the kitchen seem larger and add continuity to the space.
Jim
Jim McClain is offline   Reply With Quote
Old 05-11-2013, 10:03 PM   #6
Too Short? Cut it Again!
I have had hardwood and bamboo installed in kitchens with no problems. You do need to make sure it is quality material and that you finish it properly. Wipe spills promptly.
I especially like bamboo for kitchens. Duro-design is a fave supplier. Bamboo is harder than domestic hardwoods.
http://www.duro-design.com
That said, it depends on how much wear and abuse your kitchen gets. You can get woodlook tile to blend with your other floors that may hold up better to kids and pets.
Old 05-12-2013, 03:04 AM   #7
Rewards Points: 744
Jim
Ceramic doesn't dent, but it does chip.
Seattle2k is offline   Reply With Quote
Old 05-12-2013, 03:28 AM   #8
Yes, I know. My point was, ceramic/stone is far more impervious to damage than other traditional flooring used in kitchens. And my opinions are based on proper installation techniques.
Jim
Old 05-12-2013, 04:55 AM   #9
Again, quality makes all the difference short of dropping something heavy. Highend tile should take a lot to chip it.
The Following User Says Thank You to user1007 For This Useful Post:
Jim McClain (05-12-2013)
Old 05-12-2013, 08:51 AM   #10
Pro
JetSwet's Avatar
Rewards Points: 502
Not always the case a tile like travertine is a softer tile and shouldn't be installed in high traffic areas imo.
Ceramic is not as sturdy as porcelain as porcelain has a PEI rating for durability.
JetSwet is offline   Reply With Quote
How to Install Semi Solid Oak Flooring jastin123 Flooring 0 07-19-2012 12:51 AM
Lumber Liquidators Bud Cline Flooring 11 10-28-2011 03:00 PM
asbestos in our ripped up flooring?? 6fthook Flooring 16 07-30-2011 12:06 AM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 09:00 PM
