Flooring Issues - Flooring - DIY Chatroom Home Improvement Forum
Old 10-22-2012, 11:15 AM   #1
Unhappy
Flooring Issues
A little description/history before the questions:
Currently my wife and I are remodeling our kitchen. The new kitchen will extend ~6" into our dining area and therefore we are hoping to be able to extend the dining area. The dining area and kitchen are kind of combined in one rectangle and past the dining area is the living room. Between the living room and the dining area is a "fake" wall that has a ~2.5' (from the floor) shelf section and the remainder originally had trellis that has since been removed. This wall does not go all of the way to the ceiling and therefore is not a support wall. The wall runs east to west with a ~4' long section on the west wall and a 1.5' long section on the east wall. The wall is ~6" in width. We are wanting to remove this wall, but do not know what to do with the floor and if possible, we do not want to have to replace all of the flooring.
We have laminate flooring throughout the kitchen, dining area, living room and hallway to the bedrooms, but not in the bedrooms. The flooring runs north to south.
We have thought about running laminate across the opening that would be created if the wall were removed, but the way laminate flooring is designed (at least how I understand it) it would be very difficult, if not impossible to install across this section (by removing the cut boards and replacing with ones that would cross the gap) without dismantling the floor and then reinstalling it.
We have thought about installing a strip of laminate east to west but that has visual issues and the edges of the flooring in this area would be troublesome for many reasons.
Are there any suggestions for what could be done for this area?
ArrogantFool is offline   Reply With Quote
Old 10-22-2012, 11:22 AM   #2
Rewards Points: 12,878
Unless you installed trasition strips as a border just patching in spots is not going to work.
As you already know the floor would have to come out to that point and be relaided.
Old 10-22-2012, 11:41 AM   #3
funfool's Avatar
Rewards Points: 534
Off hand, only thing I can think of.
Use a 6" wide piece of oak going north to south with a small transition piece on both sides.
My thought is, if you use the same laminate flooring there, is going to look like a patch or a mistake.
By using oak or maple, something that will contrast well with existing floor.
Or maybe install some decorative tile.
You will still know it is a patch, guest may think it was planned that way.
Would be a lot cheaper then replacing the whole floor.
Which you still may decide to do at a later date.
funfool is offline   Reply With Quote
Water issues and flooring sherileep Flooring 2 06-26-2012 03:49 PM
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 09:53 PM
Any issues with putting Allure flooring over a bathroom tile foor? BIGDOG2513 Flooring 1 03-05-2009 02:59 PM
Basement flooring options.. Tommy2 Flooring 9 02-14-2009 08:06 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 12:32 PM
