Flooring Help - Flooring - DIY Chatroom Home Improvement Forum
Old 01-26-2008, 10:08 AM   #1
flooring help
hello,
I am wondering if anyone could give me their best advice? I wanted to have ceramic tile put in my bathroom so after buying everything and getting up to the install of the cement board, i decided that i would like the wood float floor more. The problem is the cement board is already layed do i need to take all of that up in order to use the "float floor"? Is there any other type of flooring i can lay on the cement board other then ceramic?
thank you the confused one!
boo28_77 is offline   Reply With Quote
Old 01-26-2008, 10:37 AM   #2
Eibwen
Dear Cornfused Flooring One,
If you have the cement board down tight and right I would think you could put something other than ceramic over it. But keep in mind if the new product you select requires nailing thru the cement board it could be fun.
ANNNNNND your floor is getting taller all the time so thats one thing to keep in mind.
I really dont like wood floors in baths and my suggestion would be to proceed with the tile. Once its down you'll love it. I think it will be more durable and add more long term value than a wood product.
Sammy is offline   Reply With Quote
Old 01-26-2008, 04:39 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 422
I agree, NO wood if it's a regular bathroom. Even if it's one of those laminate beauties. You made the proper choice in the first place.
Jaz
Old 01-26-2008, 06:45 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You could install the floating floor over cement board, But any flooring product made of or partially made of wood/wood products is not recommended in a wet environment - like a bathroom.
The only exception, I could think of, is maybe a 1/2 bath (no shower/tub) with the seams glued and all the edges sealed with silicone...and even that's chancing it, if your toilet overflows....
- Build Well -
Bathroom Flooring? Whole House Flooring? leezarrd Flooring 9 02-08-2012 01:47 PM
How to cut exhisting flooring in the doorway jjpar Flooring 8 10-26-2011 11:01 AM
Gameroom basement flooring? PaulMcC Remodeling 4 03-09-2006 09:08 AM
