Flooring Choices For Sealed Concrete Below Grade - Flooring - DIY Chatroom Home Improvement Forum
Old 12-02-2009, 09:32 AM   #1
Flooring choices for sealed concrete below grade
I have a dry [6 years and counting] basement with a concrete floor. The floor was sealed and the expansion joints polyurethane caulked due to a radon issue. Over the sealant is latex floor paint that has done perfectly well over the past 6 years....no issues at all.
My plan was to ceramic tile this until I started reading things....not tiling over paint and sealers...don't want to de-radon proof my floor by sanding.
So this leave me with laminate as my best likely choice in most of the area [some will get rubber gym flooring of some type]
Any recommendations on both the laminate and rubber....my research has led me to High Pressure laminate with a rating of 3 or above on wear finish....anything I am missing or not considering that I may want to think about?
....ALSO....I think I would be very happy installing a no glue laminate! Any suggestions on which of the millions is better??
Oxymoron is offline   Reply With Quote
Installing engineered hardwood flooring over concrete deborahs Flooring 3 07-30-2009 09:35 PM
Basement flooring choices Brik Building & Construction 23 01-27-2007 02:38 PM
Cypress Plank flooring over concrete therishel Flooring 1 07-17-2006 07:14 PM
Concrete Flooring kyleGR Flooring 11 10-07-2005 11:30 PM
