Flooring Choice For A Unheated 3 Season Room, But Well Insulated In Southern CT - Flooring - DIY Chatroom Home Improvement Forum
Old 09-03-2011, 12:29 PM   #1
Flooring choice for a unheated 3 season room, but well insulated in Southern CT
Are solid hardwood oak or maple flooring good choices for an unheated, 3 season sunroom, insulated with R30 in the roofed ceiling, R 19 insulated under the 2nd story floor? The sunroom is the S/W exposure, 3 sided floor to ceiling dual pane argon filled windows, double glazed for winter heat retention and summer heat blocking? The longest side is against the house and the shortest side goes out from the house. The 3 season porch is entered frm the slider in the dining room, also behind the kitchen and one bathroom, gloing down length along the house. Also condsiderating engineer wood, floating floor. I understand that wood expands and contracts, thus space will be left under the molding for movement, also underlayment. The plywood base is 50yr waterproof. Thanks for your sharing of experience and opinions.
woodscarol is offline   Reply With Quote
Old 09-03-2011, 05:25 PM   #2
Rewards Points: 200
Ever hear of the Greenhouse Effect ?
You will be replacing that floor .
Floor Doc is offline   Reply With Quote
New Laminate Flooring In Living Room zmurphy Project Showcase 9 05-07-2008 11:15 AM
Hardwood flooring - 3 walls and a sunken living room basledder Flooring 1 12-09-2007 05:34 PM
Laminate Flooring Flowing from Room to Room frskelly Flooring 1 09-15-2007 11:14 PM
Flooring Choice NewDIY Flooring 1 01-02-2007 11:35 PM
Sealing southern pine flooring DMA Flooring 1 02-28-2006 09:37 AM
