Flooring & Cat Urine - Flooring - DIY Chatroom Home Improvement Forum
Old 03-26-2010, 01:01 PM   #1
Flooring & cat urine
Hi all. New to the forum.
I'm looking to install a wood/engineered/laminate floor over concrete. We have cats with bladder issues. And they're sneaky about it.
I read an earlier post about the ineffectiveness of sealing seams with glue or caulk. And I'm not much interested in vinyl.
Is there a product and/or installation system that will withstand cat pee?
Many thanks
Jeff11 is offline   Reply With Quote
Old 03-26-2010, 01:07 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 124
Concrete.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 03-26-2010, 01:13 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
cat diapers
realistically, if you have a cat that urinates or sprays in places you don't want them to, you are really limited to options.
If you want wood, my best suggestion would be it NOT be an engineered floor but an old fashioned plank installation with all the sanding and finishing that included. By using a good finish, it would provide very resistive surface. You would still have to deal with the intersection of wall meets floor as many cats spray and it can run down the wall and under the flooring.
Old 03-27-2010, 11:06 AM   #4
2nd Gen. Tile Setter
Originally Posted by rusty baker View Post
Concrete.
Um... No. The acid in the urine will etch the concrete.
Porcelain tile w/ Epoxy grout would be the way to do. Almost impervious flooring.
DeWoof01 is offline   Reply With Quote
Old 03-27-2010, 11:40 AM   #5
Rewards Points: 124
You are right, I forgot about that. Maybe they should just use dirt. They could rake it once a week.
Old 03-27-2010, 12:24 PM   #6
true. Just make a floor of cat litter. The best thing to do is to go to the vet and see what the cats problem is. Cat urine has a horrible odor and you don't want it absorbing into anything.
Old 03-27-2010, 12:51 PM   #7
Rewards Points: 124
A vet told me that tom cats can spray on the ceiling.
Old 03-27-2010, 05:35 PM   #8
I'm thinking an oriental sand garden with several large rocks that you can rake daily into meditative patterns.
The older I get the better I was
Old 03-27-2010, 08:41 PM   #9
Ivy
Not sure how it works on concrete but I recently used B.I.N. to get rid of odors and stains of old animal urine in the subfloor...
Ivy is offline   Reply With Quote
Old 03-29-2010, 05:59 PM   #10
An epoxy coated floor will do the trick. It's used in kennels, slaughter houses, even the chimp area and lion den at the Baltimore Zoo. Chimps are very sensitive to many chemicals, and good epoxies are zero VOC or HAPs, lions are just tough on floors all around, but the epoxy holds up well to their claws and urine, cats are easy in comparison.
AlphaGarage is offline   Reply With Quote
Old 03-30-2010, 11:42 PM   #11
Rewards Points: 508
Both the epoxy coating and the porcelain seem like great recommendations. Here's another idea: http://www.radonseal.com/concrete-sealers.htm. One of the products specifically says that it resists acids.
On a different note, if you need to get rid of cat urine odors in fabrics, etc., I recommend a commercial ozone machine.
Find a company that will bring one in, or buy one yourself. Don't waste any money on the cheap ozone air fresheners. My commercial generator puts out 16,000 mg/hr.
Use these machines with caution; they break down all things organic (e.g., you upper respiratory system) , and they can leave some unpleasant residual compounds if not employed properly. You can't argue with the results, though. I washed a car seat cover that had been soaked in pungent urine for days. I used lots of OxyClean and multiple high temperature washes, but the smell remained pretty strong. After a few hours in an enclosure with the ozone generator, the carseat cover was completely free of the smell. I stuck my nose right in the thing without catching even a hint of the smell. Good luck!
benjamincall is offline   Reply With Quote
Tags
wood laminate pet urine
Lots of Urine Damage Jordan Berry Flooring 7 10-19-2009 11:06 AM
Strange engineered wood flooring install in Philippines (pics) Flt_Simulation Flooring 7 10-05-2009 09:00 AM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
Basement flooring options.. Tommy2 Flooring 9 02-14-2009 07:06 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 11:32 AM
