Flooring Bondo Or Wood Hardener - Flooring - DIY Chatroom Home Improvement Forum
Old 09-03-2013, 08:44 AM   #1
Rewards Points: 1,402
Question
Flooring Bondo or Wood Hardener
Hi all.
I'm doing a medium-term repair on the results of a long under-sink leak. There's no floor, but a tile-on-plywood insert that sits about three inches above the subfloor had warped, the drywall was in bad shape at the base, and the subfloor itself is a bit rotted. (The heavy cast iron radiator sort of sinks into it at the worst part, for example, although certainly not all the way through.)
It doesn't make sense to replace the subfloor until the next time someone does a kitchen remodel on the house--you'd really have to pull the counter and 10+ feet of of deep custom kitchen cabinets out to make it perfect, and probably the finished floor as well. So I'll replace the bottom few inches of drywall and the insulation behind it, put down some thin plywood or laminate flooring before replacing the radiator (this will spread out the weight and provide some spill protection), and build a new tile insert.
My question is, does it make sense to do anything to the exposed portion of the subfloor before covering it? I've heard people use epoxy ("bondo") or wood hardener and wood filler for rot repairs sometimes. It seems like it would take a lot of filler. Do these actually make the wood stronger, or is the result really cosmetic and I shouldn't worry because the wood will be covered?
Tom738 is offline   Reply With Quote
Old 09-03-2013, 12:59 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 42
If you are just leveling it, I would use a cementious based floor filler. It's cheap and won't crumble even if it gets wet.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
engineered wood flooring nailer joshanah Flooring 3 06-04-2012 12:21 PM
Engineered or Solid Wood flooring on stairs VickyC Flooring 1 03-05-2010 07:50 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
