Old 07-04-2012, 10:30 AM   #1
Flooring behind rec room bar
The previous owner installed vinyl flooring behind the Rec room bar in our basement. I was thinking about changing it up with the tiles we installed in our bathrooms upstairs. These looks like they are ceramic roles, but they are not. Any thoughts?
Flooring behind rec room bar-image-1042700144.jpg   Flooring behind rec room bar-image-3263097136.jpg
dinosaur1 is offline   Reply With Quote
Old 07-04-2012, 01:18 PM   #2
JetSwet's Avatar
That's sheet linoleum, you won't be able to tile over it.
Take it up and tile on the basement floor.
JetSwet is offline   Reply With Quote
Old 07-05-2012, 12:38 AM   #3
Why won't we be able to?
Old 07-05-2012, 07:02 AM   #4
JetSwet's Avatar
Well technically you can, but I wouldn't suggest it.
Thinset usually never sticks to it for long, even though it's glued to the slab there are little pockets of air you can't tell by walking on it now but there there. so when you lay tile down and then walk on it there will be movement and that will lead to grout cracking then tiles will soon after shift on you.
Old 07-05-2012, 07:27 AM   #5
Pro Flooring Installer
rusty baker's Avatar
Is that box peel and stick? Looks like it.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
The Following User Says Thank You to rusty baker For This Useful Post:
oh'mike (07-05-2012)
Old 07-05-2012, 07:37 AM   #6
JetSwet's Avatar
Looks like ceramic tile to me
Old 07-05-2012, 08:16 AM   #7
Peel and stick but it looks and feels like ceramic. 3 times thicker than regular vinyl.
Old 07-05-2012, 08:28 AM   #8
JetSwet's Avatar
Well forget what I said then.... My bad thought it was ceramic.
Old 07-05-2012, 08:43 AM   #9
When we did our refi the inspector wrote down that we have ceramic tiles in our upstairs bathrooms. He couldn't tell the difference.
Old 07-05-2012, 03:00 PM   #10
JetSwet's Avatar
There's a big difference between ceramic and groutable P&S tile one can bend and one brakes in to pieces.
Old 07-05-2012, 06:54 PM   #11
This is how it looks in our bathroom.
Old 07-05-2012, 07:22 PM   #12
JetSwet's Avatar
Looks good, some pros don't like using p&s for what ever reason I put 18x18" In my hallway and office looks nice I think.
Old 07-05-2012, 07:31 PM   #13
Thanks. Now I need to find a nice color for behind the bar area downstairs.
Insulating a cold/well room? Lynch Building & Construction 22 02-09-2013 08:51 AM
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 07:37 PM
Vents from boiler room RammsteinNicCage HVAC 3 03-11-2009 08:28 PM
New Laminate Flooring In Living Room zmurphy Project Showcase 9 05-07-2008 12:15 PM
Concrete Flooring in Safe Room GorillaBoze Building & Construction 3 03-05-2008 04:01 PM
