Flooring behind rec room bar
2 Attachment(s)
The previous owner installed vinyl flooring behind the Rec room bar in our basement. I was thinking about changing it up with the tiles we installed in our bathrooms upstairs. These looks like they are ceramic roles, but they are not. Any thoughts?
That's sheet linoleum, you won't be able to tile over it.
Take it up and tile on the basement floor. |
Thinset usually never sticks to it for long, even though it's glued to the slab there are little pockets of air you can't tell by walking on it now but there there. so when you lay tile down and then walk on it there will be movement and that will lead to grout cracking then tiles will soon after shift on you. |
Is that box peel and stick? Looks like it.
1 Attachment(s)
Looks good, some pros don't like using p&s for what ever reason I put 18x18" In my hallway and office looks nice I think.
| All times are GMT -4. The time now is 03:40 PM. |
