Flooring Before Ikea Kitchen Cabinets, Or After? - Flooring - DIY Chatroom Home Improvement Forum
Old 07-19-2015, 01:27 PM   #1
Rewards Points: 68
Flooring before Ikea kitchen cabinets, or after?
Hi all. I am getting close to flooring install. I will be installing an Ikea kitchen (small L-shaped layout in left corner of pic), and am trying to figure out whether to install kitchen base cabinets before flooring... or flooring first and THEN install base cabinets? It seems that the Ikea cabinets are meant to use over finished flooring, on feet, covered/hidden by a toe kick.
I will be installing a floating floor ('hand-scraped appearance' laminate). The room is 22' x 11', and is kitchen open to living area. Jut a small 1+1 weekend cabin. Will installing the cabinets over a floating floor cause issues concerning the expansion and contraction of the floating floor?
Thank you for any info!
Kory Beam is offline   Reply With Quote
Old 07-19-2015, 01:42 PM   #2
Rewards Points: 448
It is usually done after and will save you money in materials.
BrowneBearLLC is offline   Reply With Quote
Old 07-19-2015, 03:30 PM   #3
DIY staff
Rewards Points: 6,252
This is a never ending debate----I always do the floor first--yes, a bit more materials, but faster to install the flooring first--fewer cuts--and far easier to install the cabinets--
No filler plywood --less shimming---
It's your call----I doubt if pinning that corner down with the cabinets will be an issue.
oh'mike is online now   Reply With Quote
Old 07-19-2015, 03:43 PM   #4
Rewards Points: 2,818
I always install the entire floor and put the cabinets on top. The extra cost is not that much.
Ron
B. Franklin 1759
Old 07-19-2015, 04:03 PM   #5
Rewards Points: 1,724
Floating floor fine, cabinets on top so the floor, clean, nice fit, etc. now if y were stalling 3/4" flooring, you could mark an inch or so behind the toe kick and fill that whole space with 3/4" plywood, but more trouble than it worth unless you are using really expensive flooring. Ron
ront02769 is offline   Reply With Quote
Old 07-19-2015, 04:07 PM   #6
Rewards Points: 68
Thank you, gentleman. Flooring has already been purchased. I bought enough to cover the entire floor plan, so... no worries about material savings.
Another question... living room/kitchen area is above conditioned space (finished office/utility room below), but the hall and back bedroom are above unfinished crawl space. Subfloor is obviously ply (3/4" TXG). Should I use a laminate underlayment with an air/moisture barrier for the whole job? Makes sense.
Old 07-19-2015, 04:24 PM   #7
DIY staff
Best to be cautious---I'd use the better underlayment under the entire floor.
Kory Beam (07-19-2015)
Old 07-19-2015, 05:24 PM   #8
Clarification
I put tile floors, glue down and nailed hardwoods under cabinets. Floating floors need to expand and contract, so they need to be at least 1/4" away from fixed items. Before you install anything under a cabinet, check with the manufacturer about it.
If the floor can't expand it will buckle.
Ron
B. Franklin 1759
Old 07-19-2015, 07:51 PM   #9
Rewards Points: 68
The install notes for this laminate floor call for 5/16" - 3/8" expansion around all fixed objects.
It looks like the Ikea cabinet installation instructions have the base cabinets attached to rails on the walls... with the front legs resting on the floor. Can't tell if there are also rear legs.
I saw that somebody installed their Ikea cabinets by fixing ledger boards to the walls for the rear bottoms of the cabinets to rest on. The adjustable front legs were the only points of weight resting on the finished floor.
Old 07-19-2015, 10:05 PM   #10
It's not just the weight of the cabinets, it's all the stuff that goes into them.
I'd call the floor manufacturer and get their recommendation.
Ron
B. Franklin 1759
Old 07-21-2015, 10:48 AM   #11
Rewards Points: 68
Thank you, Ron.
I called the manufacturer... and they advised not to install the cabinets on the finished laminate. They want cabinets first, then floor up to the cabinets, leaving the usual expansion/contraction gap of 3/8".
If I do install cabinets first, will I be wanting to raise the floor height under the cabinets to match the finished laminate floor height?
Old 07-21-2015, 11:01 AM   #12
Sort of a personal choice. You'll have kick plates under the cabinet so you can't see under there and the kick plates will keep any debris from rolling under there.
If liquid spills and goes under the kick plate, you can easily clean it up by popping off the plate.
Ron
B. Franklin 1759
Old 07-28-2015, 10:32 PM   #13
Plumber
TheEplumber's Avatar
Rewards Points: 2,072
From a plumbers perspective- be sure you have room to slide in the dishwasher- 34" is standard height
Old 07-30-2015, 02:22 PM   #14
Rewards Points: 246
It depends upon the flooring you are going to choose for your kitchen floor. If you are going for wooden floor then you should complete that first because it’s a tedious task as compared to installation of cabinets. But otherwise also I would suggest go for flowing first and everything afterwards.
fortunerestore is offline   Reply With Quote
Cabinets To Go! CapnHawk Kitchen & Bath Remodeling 61 07-05-2015 01:58 AM
Kitchen cabinets base "moulding" lzena Carpentry 12 09-02-2012 08:50 AM
installing used kitchen cabinets xcuter Kitchen & Bath Remodeling 1 07-19-2010 01:39 PM
diy built-in kitchen cabinets Jeremy Hillary Boob, PhD Carpentry 6 11-29-2008 11:46 PM
