Flooring For Basement Workshop? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-30-2013, 10:11 PM   #1
Rewards Points: 203
Flooring for Basement Workshop?
Hello,
I'm looking for some suggestions. I'm renovating a basement workshop that currently has asbestos floor tiles. The tiles are mostly intact and I would prefer to cover them as opposed to removal. I'm also trying to avoid drilling into these tiles since I'm pretty sure they're made of asbestos material.
This room will be primarily used for wood working, but I might also bring in some heavy items and need the flooring to be durable. Any suggestions? I'm not too concerned about price as the room is not huge. I was hoping there might be some kind of a floating wood floor option.
Thanks in advance.
Jim Ignatowski is offline   Reply With Quote
Old 03-31-2013, 07:47 AM   #2
Rewards Points: 13,296
A vaper barrier and engineered flooring is one option.
Old 03-31-2013, 08:59 AM   #3
Rewards Points: 1,446
I would do both of:
1. Paint the floor with a paint that is good enough to "encapsulate" the asbestos.
2. Put down a durable "finish" floor.
Even with a finish floor on top, some chipping of the asbestos flooring will occur and the encapsulating layer will at least keep most of the pieces large as opposed to produce asbestos dust.
AllanJ is online now   Reply With Quote
Old 03-31-2013, 09:43 AM   #4
Waste of time but if it makes you feel better it's not going to do any harm.
Old 03-31-2013, 11:11 AM   #5
Rewards Points: 203
Thanks for the responses. Has anyone had any experience with waterproof floating vinyl flooring? Since I'm in a basement I like the idea of something that can handle water/moisture. The stuff looks like wood, I'm just not sure how durable it is.
Old 03-31-2013, 05:36 PM   #6
woodman58's Avatar
Vinyl to me would not be an option. If it gets cut it will open up bigger. I am a hardwood floor installer by trade and a woodworker by heart. I would make sure all the tile are secure to the floor and then give them a good cleaning. when this is done you can put an epoxy floor down. It is easy to do. You can get the kits from the box stores. It is a very durable floor. I have painted several on garage floors.
I LOVE THE SMELL OF SAWDUST IN THE MORNING!
woodman58 is offline   Reply With Quote
Old 03-31-2013, 11:16 PM   #7
Rewards Points: 203
That's a good suggestion, I never considered an epoxy flooring. One issue might be that a few of the floor tiles are missing. I guess I would need to figure out a way to level those areas prior to pouring on the epoxy?
I attached a picture of the room.
Old 04-01-2013, 08:09 AM   #8
woodman58's Avatar
You can use a good floor leveling compound to level where tile are missing and taper down the areas where needed, then put the epoxy on.
Old 04-01-2013, 08:20 AM   #9
woodman58's Avatar
Make sure all tile are sucure.
Tags
basement flooring , workshop
How to Install Semi Solid Oak Flooring jastin123 Flooring 0 07-19-2012 12:51 AM
Lumber Liquidators Bud Cline Flooring 11 10-28-2011 03:00 PM
asbestos in our ripped up flooring?? 6fthook Flooring 16 07-30-2011 12:06 AM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 09:00 PM
