Old 01-10-2009, 04:09 PM   #1
Flooring and Baseboard Removal
Hello,
Is there a flooring that I could install that doesn't require the removal of the baseboards?
hammermonkey is offline   Reply With Quote
Old 01-10-2009, 04:45 PM   #2
What is your reason for not wanting to remove the baseboards? Some people will add a peice of shoe moulding when they don't want to remove the base.
ponch37300 is offline   Reply With Quote
Old 01-10-2009, 04:54 PM   #3
Well, we are trying to do what is most economically efficient. We have to replace the flooring in the entire house, so with little money, we are trying to cut corners where possible.
Old 01-10-2009, 07:45 PM   #4
Floorwizard's Avatar
you will still need to buy 1/4 round to finish it off so there will still be a cost, but removing and resetting is free if you do the work.
Floorwizard is offline   Reply With Quote
Baseboard on two different floor levels. anthony9887 Flooring 2 08-11-2008 04:48 PM
sub flooring removal question matchley Flooring 7 10-02-2007 09:19 PM
Need help with finding very wide baseboard Showbiz Carpentry 2 05-28-2007 08:52 AM
