Old 05-18-2012, 09:45 PM   #1
Flooring above garage slab
I am working on a property that is basically a 25'x30' garage on a slab foundation that has been "finished" rather poorly into a living space.
The floors were uneven, so I ripped up the tile and unscrewed a layer of 3/4" t&g to find PT 2x4s on their sides secured to the slab foundation holding up the sub floor. No vapor barrier or insulation of any kind.
The floor can likely be leveled with some shims on the 2x4s, but should I be adding a vapor barrier before I attached the 3/4" subfloor again?
farang is offline   Reply With Quote
Old 07-15-2012, 09:05 PM   #2
any help?
Laminate wood flooring on slab newb questions shark974 Flooring 3 11-11-2011 06:57 AM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 04:56 PM
need to fix the foundation on this slab garage cnn7 General Discussion 3 04-20-2010 06:11 PM
Sink hole under garage slab. diggitydog Building & Construction 3 08-31-2006 01:49 PM
