Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 03-27-2010, 09:47 AM   #1
Flooring
I'm having a sunroom built and I would like any idea's about flooring. I'm thinking about engineered wood. Should it be floating or glued? I want to put it down myself. It shouldn't be hard.
Thanks for your help,
Mike
bartendmk is offline   Reply With Quote
Old 03-27-2010, 10:02 AM   #2
Where are you located ?
What material for the subfloor ?
Old 03-27-2010, 10:32 AM   #3
I'm located in New Jersey and the subfloor will be plywood.
Old 03-27-2010, 11:40 AM   #4
flooring
I putting a sunroom on my deck and I was wondering what kind of flooring I should use. I like engineered wood. Should it be floating or glued? It seems like it would be easy. Any thoughts?
Thanks,
Mike
{2 threads on same topic merged}
Moderator
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 06:37 PM
Strange engineered wood flooring install in Philippines (pics) Flt_Simulation Flooring 7 10-05-2009 09:00 AM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
Basement flooring options.. Tommy2 Flooring 9 02-14-2009 07:06 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 11:32 AM
