Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 10-20-2006, 07:11 PM   #1
Flooring
we have a crawl space over dirt under our house. Leaks in thr 50 year old copper rotted the floors in some places. In replacing the wood, should we put a vapor loc layer between the sub floor and and top floor? What is suggested?
sflbon52 is offline   Reply With Quote
Old 02-27-2007, 12:05 AM   #2
The proper placement of vapor barrier would be between the insulation and the heated space. If you do not have any vapor lock or insulation in place, I would think it would be better then none. I have seen many laminate flooring use a vapor lock type membrane beneath them so I would think its fine. I would still recommend insulating the floor at some point.
Mgmopar
MgMopar is offline   Reply With Quote
Old 02-27-2007, 08:25 AM   #3
Dear S-52, Welcome to the forums I don't know where you are writing from but insulation is always recommended between heated and unheated (cooled and uncooled) spaces, and an integral vapor barrier is a good idea too. It's important also that your crawl space have ventilation.
Best wishes,
Steve
sfixx is offline   Reply With Quote
