Old 06-10-2012, 12:40 PM   #1
Flooring
What is the process for replacing carpet with vinyl or stick on tile? Any common pitfalls I should know before starting?
msk1865 is offline   Reply With Quote
Old 06-10-2012, 12:49 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Flooring
The floor must be perfectly smooth. Any imperfections will show.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 06-11-2012, 11:14 PM   #3
Flooring
Remove the carpet, pad and tack strip. Then remove all staples, sweep really well and then add the vinyl or stick down tiles if you have a nice, clean plywood subfloor. If you have another type of subfloor; osb, particle board, pine planks etc, I would first add a layer of 1/4" luan prior to adding the vinyl. It will stick better. The luan is stapled down.
RhodesHardwood is offline   Reply With Quote
The Following User Says Thank You to RhodesHardwood For This Useful Post:
PaliBob (06-11-2012)
Lumber Liquidators Bud Cline Flooring 11 10-28-2011 03:00 PM
asbestos in our ripped up flooring?? 6fthook Flooring 16 07-30-2011 12:06 AM
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 09:53 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 09:00 PM
