-   -   Flooring (http://www.diychatroom.com/f5/flooring-146612/)
msk1865 06-10-2012 11:40 AM
Flooring
What is the process for replacing carpet with vinyl or stick on tile? Any common pitfalls I should know before starting?
rusty baker 06-10-2012 11:49 AM
The floor must be perfectly smooth. Any imperfections will show.
RhodesHardwood 06-11-2012 10:14 PM
Remove the carpet, pad and tack strip. Then remove all staples, sweep really well and then add the vinyl or stick down tiles if you have a nice, clean plywood subfloor. If you have another type of subfloor; osb, particle board, pine planks etc, I would first add a layer of 1/4" luan prior to adding the vinyl. It will stick better. The luan is stapled down.
