Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 04-21-2012, 12:36 AM   #1
Flooring
I'm remodelling our upstairs bathroom - this includes installing bamboo flooring. The floor joists are spaced at 19" - 20" intervals. Over these are nailed 3/4" planks that were a floor for carpeting. Some nails have popped up but can be put back into place by hammering them. I do plan to add 2 1/2" self-tapping flat-head wood screws that counter-sink themselves to the planks such that I have a relatively flat surface on which to overlay with a layer of plywood. The current planked subfloor appears to be in relatively good shape.
My Question: What is the minimum plywood thickness I should be using? Also, please specify the type of plywood I should be using.
Thank you.
Frank Strouhal
akmvg89a@sbcglobal.net
Frank Strouhal is offline   Reply With Quote
Old 04-21-2012, 01:04 AM   #2
The advent of laminate flooring has changed the way designers view floors in a house. Cork flooring is one of the most versatile and affordable forms of home flooring.
glendoggett is offline   Reply With Quote
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 4 06-07-2017 06:24 PM
DuraFlex Epoxy Flooring Problem Amon Flooring 9 11-04-2013 12:47 PM
Lumber Liquidators Bud Cline Flooring 11 10-28-2011 02:00 PM
asbestos in our ripped up flooring?? 6fthook Flooring 16 07-29-2011 11:06 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
