Which Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 04-10-2012, 03:01 PM   #1
Rewards Points: 22
Which Flooring
Unheated enclosed porch between house and garage with concrete slab. Wood laminate or tile?? Gets into the 20's in mid winter most years.
Cattman is offline   Reply With Quote
Old 04-10-2012, 03:28 PM   #2
the Musigician
DangerMouse's Avatar
If it's a traffic area, I'd consider using VCT and grout.
Less maintenance and it should handle the cold weather.
Others may have differing opinions/better ideas.
DM
Old 04-10-2012, 05:10 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 82
DM
Grout VCT? Never have seen VCT grouted.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 04-10-2012, 05:17 PM   #4
the Musigician
Am I thinking of something else? Thick vinyl tiles that look like stone/tile/marble? Treated pretty much like ceramic?
DM
Old 04-10-2012, 06:34 PM   #5
Rewards Points: 82
Maybe Duraceramic?
Old 04-10-2012, 07:09 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 340
Dangermouse, although I've seen VAT, VCT, solid vinyl, cork and a host of other resilient flooring materials used in unheated areas, there aren't any that are recommended if the floor temp will go below 55 f. That means air temps of perhaps 60-65 in the room.
Ceramic tile is the one of the possibilities for this area.
Jaz
Old 04-10-2012, 07:28 PM   #7
the Musigician
What about just throwing down some sheet linoleum?
Cheap...
DM
Old 04-11-2012, 12:52 AM   #8
I would think some sort of stone. Maybe a paver looking sort of thing or bluestone. Mostly depends on what the thing looks like though
Evstarr is offline   Reply With Quote
Old 04-11-2012, 09:57 AM   #9
Rewards Points: 22
Originally Posted by rusty baker View Post
Maybe Duraceramic?
DuraStone? We have that inside and the porch is very high traffic. The durastone has not worn well in the kitchen, so likely to go with ceramic or sheet.
Old 04-12-2012, 12:53 AM   #10
How about acid staining the concrete slab?
RhodesHardwood is offline   Reply With Quote
DuraFlex Epoxy Flooring Problem Amon Flooring 9 11-04-2013 12:47 PM
Lumber Liquidators Bud Cline Flooring 11 10-28-2011 02:00 PM
asbestos in our ripped up flooring?? 6fthook Flooring 16 07-29-2011 11:06 PM
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 08:53 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
