Floor And Wall Do Not Meet At 90 Degree Angle - Flooring - DIY Chatroom Home Improvement Forum
Old 10-16-2012, 07:15 PM   #1
Rewards Points: 31
Floor and wall do not meet at 90 degree angle
I'm looking to install laminate planks in my basement but the floor does not meet the foundation walls at a right, 90 degree angle (house was built in 1940). Instead the cement floor curves upward into the wall. Looking for any solutions, can I cut and lay a plank on the angled part, cover with molding, or is there a better way to finish the edges of the floor. Thanks.
jmorc2003 is offline   Reply With Quote
Old 10-16-2012, 11:48 PM   #2
Rewards Points: 12,858
Going to have to grind it down or chose a differant type of flooring.
Old 10-18-2012, 02:17 PM   #3
Rewards Points: 31
Thanks. Grinding the corners down to form a nice edge would be ideal, but I don't think I'm ready for that big of a job. Is it as difficult and messy as it sounds? What sort of tool(s) would I use?
Old 10-18-2012, 02:48 PM   #4
Experienced
Jackofall1's Avatar
How far from the wall you talking?
A couple of pictures of this one would be handy. I certainly would not be thinking about grinding.
Mark
Old 10-18-2012, 08:25 PM   #5
Rewards Points: 31
Mark
Here's a picture. The previous owners put down vinyl tile and just bent it along the curve to meet up with the molding.
Old 10-18-2012, 09:15 PM   #6
Experienced
Jackofall1's Avatar
I would bring the flooring to the break edge and use a transition piece to a strip of similar color stained vaneer, I wouldn't mess with trying to run laminate up that slope, nor would I attempt to level it.
Mark
