Old 01-01-2013, 10:29 AM   #1
Floor under retrofitted dishwasher
Hello,
I have retrofitted a dishwasher in my older home with oak cabinets.
I used a plywood to level the floor. And now the ugly plywood is flush with the ceramic. I thought that the dishwasher's bottom cover would have covered the plywood but I was very wrong. Any ideas of an easy fix. Only thing that I came up with was finishing the plywood best I could and staining it.
Mudkicker is offline   Reply With Quote
Old 01-01-2013, 10:50 AM   #2
Super Moderator
Get a piece of oak ranch style baseboard---rip
it to the correct width---
miter both ends with little returns to hide the side openings---
glue it--
stain and finish and slip it over the ugly plywood.
Old 01-01-2013, 12:02 PM   #3
The above solution is a good one.
I suppose a temp solution would be a paint the wood black so it matches the kick plate. It would at least be less noticeable, but probably wouldn't look great.
stephen9666 is offline   Reply With Quote
Old 01-01-2013, 01:23 PM   #4
glue it--
thanks for the reply. if i glue it down, i will not be able to pull out the washer(repairs, etc.) because there will not be enough clearance.
Old 01-01-2013, 04:23 PM   #5
Super Moderator
Use silicone caulk---if you (when?) need to remove it slip a putty knife or painters tool between the trim and the floor-
--the silicone caulk will split and release the trim.
Dishwasher Drain Install w/o Sink Lyndon Plumbing 3 11-21-2011 02:10 PM
Dishwasher connection and wiring, oh boy! Bigplanz Electrical 18 06-15-2011 10:52 PM
Replacing Dishwasher, No water shutoff sustorm Plumbing 24 04-08-2011 01:56 PM
Dishwasher powder instead of salt - Doh! Bottletops General Discussion 0 03-03-2010 12:06 PM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 03:32 PM
