-   -   Floor under retrofitted dishwasher (http://www.diychatroom.com/f5/floor-under-retrofitted-dishwasher-167925/)
Mudkicker 01-01-2013 09:29 AM
Hello,
I have retrofitted a dishwasher in my older home with oak cabinets.
I used a plywood to level the floor. And now the ugly plywood is flush with the ceramic. I thought that the dishwasher's bottom cover would have covered the plywood but I was very wrong. Any ideas of an easy fix. Only thing that I came up with was finishing the plywood best I could and staining it.
http://i203.photobucket.com/albums/a...psafe83259.jpg
http://i203.photobucket.com/albums/a...pse2e5fb30.jpg
oh'mike 01-01-2013 09:50 AM
Get a piece of oak ranch style baseboard---rip
it to the correct width---
miter both ends with little returns to hide the side openings---
glue it--
stain and finish and slip it over the ugly plywood.
stephen9666 01-01-2013 11:02 AM
The above solution is a good one.
I suppose a temp solution would be a paint the wood black so it matches the kick plate. It would at least be less noticeable, but probably wouldn't look great.
Mudkicker 01-01-2013 12:23 PM
glue it--
thanks for the reply. if i glue it down, i will not be able to pull out the washer(repairs, etc.) because there will not be enough clearance.
oh'mike 01-01-2013 03:23 PM
Use silicone caulk---if you (when?) need to remove it slip a putty knife or painters tool between the trim and the floor-
--the silicone caulk will split and release the trim.
