Old 07-24-2012, 07:29 PM   #1
Floor Trim Ideas Needed-How 2
I am replacing carpet w/6 X 36 vinyl planks on a concrete floor. After getting the carpet up I have found that between the sheet rock and the floor there is about 1/4 inch, which of course the molding that I had to also remove hid this to my eye. Needing a smooth surface for the planks I have noticed the concert floor at the edge of the sheet rock is very rough. I need somehow to extend my wall out a little to get a straight edge to start the planks and a molding idea to lie down on the planks once they have been installed. I am a novice at this.
jalex1951 is offline   Reply With Quote
Old 07-24-2012, 07:57 PM   #2
You will need a patch grey preferd and patch where the carpet tack strip was make as smooth as possiable. To start the vinyl planks measure out from an outside wall (most square). Make marks on floor about 4 planks wide ex. 4 inch planks measure out 16 inches, snap a chalk line and glue this area. Start planks on the chalked line and work back to wall, let set then work your way out. As for the trim add quarter round it makes for a nice picture frame look. Good Luck!
Iflooru is offline   Reply With Quote
The Following User Says Thank You to Iflooru For This Useful Post:
jalex1951 (07-24-2012)
Old 07-25-2012, 09:27 AM   #3
what is patch gray prefered and patch
Old 07-25-2012, 10:16 AM   #4
Pro Flooring Installer
rusty baker's Avatar
No idea and I have been an installer for 40 years.
Just use a cemetious based patch, not gypsum based and you will be fine.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 07-26-2012, 08:31 PM   #5
I find using color such as grey for cementious and white for gypsum, maybe easier for a novice to find.
Exterior entrance ideas needed ryanb4614 Remodeling 7 07-16-2012 10:52 AM
Closet Vanity ideas needed ryanb4614 Carpentry 6 06-28-2012 12:09 PM
Joining 1/4" walled poly pipe IDEAS NEEDED!! CallMeChaz Plumbing 0 05-22-2012 10:04 AM
Any good ideas out there for a garage workshop divider? DIYguy2000 General Discussion 1 04-19-2012 05:18 PM
Ideas needed for a floorplan SAS Remodeling 3 09-05-2009 08:18 AM
