Old 10-02-2012, 02:22 PM   #1
Question
Floor Track Stuck Under Wall
Hi. We are putting new laminate floors down.
The previous home owners built a wall right over top of a strip of metal floor track. (The stuff that separates one type of floor from another.)
We have to remove the floor track because it doesn't allow the laminate planks to have the correct spacing from the wall, 1/4-1/2 inch.
What is the best way to remove the track? I hope it doesn't involve cutting the drywall above it or the plywood beneath it!
I couldn't get my camera to upload so I "painted" a picture of it.
Thanks for any advice.
mamabear is offline   Reply With Quote
Old 10-02-2012, 03:25 PM   #2
Without that picture not sure what it is your talking about from that picture.
Could be a trasition strip your talking about.
If so it's just nailed to the floor, but your saying they built a wall on top of it which makes no since.
Old 10-02-2012, 04:01 PM   #3
are you sure it goes under the wall and not just under the baseboard? an angle grinder or a sawzall with a metal blade or even a hacksaw blade in a holder would work to cut it flush on either side.
Old 10-02-2012, 04:57 PM   #4
Even a wack with a chisle straight down will snap it off.
oh'mike (10-02-2012)
Old 10-02-2012, 11:05 PM   #5
yes, I do believe it's called a transition strip.
yep, it's under the wall and not just under the base board. The baseboards are already removed. It's peaking out the one side of the wall to much for the trim to hide, so we have to remove it. The wall obviously never used to be there, and I'm not sure why they wouldn't just remove the transition strip first before constructing the wall.
The transition strip is screwed to the floor, not nailed.
Thanks for your help. We tried a second time to push in under the drywall so it wasn't peaking out anymore and we think that will do the trick. He used a hammer and some other flat headed tool. If we have problems when we are laying our floor along that little wall, we will try your ideas.
Old 10-02-2012, 11:20 PM   #6
Super Moderator
Joe nailed it---wood chisel and a hammer will cut that right off.
Retaining wall work-- what approach? emcelvaney Landscaping & Lawn Care 2 09-24-2012 08:49 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
