Floor Too Long For Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 04-07-2012, 10:32 AM   #1
mokismom's Avatar
Floor too long for tile
Help! I have 121" wall and 13" tile. What do I do with the extra 1-2"? (with 1/4" spacers). Could I go bigger spacers? Or must I end up with a little excuse of a piece at one wall?
mokismom is offline   Reply With Quote
Old 04-07-2012, 12:12 PM   #2
Remodeling Contractor
What size baseboard trim are you installing? This may make up the difference. But a small piece on one end will not be so terrible.
Old 04-07-2012, 12:14 PM   #3
Rewards Points: 13,276
What room is it? If it's a bathroom I start laying the tile in front of the tub where it's going to be seen with full tiles and make all my cuts on the back wall where in most cases there's going to be a vanity and toilet covering it up.
Old 04-07-2012, 12:15 PM   #4
bbo
you can do 6 3/4 on each end.
but really, 1/2 is only 1/4 n each end which is easily covered with trim.
bbo is offline   Reply With Quote
Old 04-07-2012, 01:05 PM   #5
mokismom's Avatar
Laundry room, and maybe I will put small piece under washer and dryer. You're right, baseboard may cover most of it.
BUT another ? ... When laying directly onto cement, can I trowel the 1/4" trowel edge right down to cement?? Or do I need to have a layer of thin set down, then add another layer on top that I trowel with the 1/4" ???
Old 04-07-2012, 01:15 PM   #6
Rewards Points: 6,652
You really need to dry lay, then adjust the tile from there to get the proper measurement, so that you have the same sized cut tile on all outside edges.
Old 04-07-2012, 01:23 PM   #7
mokismom's Avatar
Otherwise the store person said to etch the cement first... Seems that they are just trying to sell me more stuff
Old 04-07-2012, 01:46 PM   #8
no they are telling you to do the job right. Etching will assure that the thinset gets a good bond.
Old 04-07-2012, 05:44 PM   #9
Pro
JetSwet's Avatar
Rewards Points: 502
Have you considered maybe a diamond pattern?
JetSwet is offline   Reply With Quote
How long between tiling steps? ptraz Flooring 4 03-12-2010 08:13 PM
How long does it take for Aura to cure? slickracer Painting 8 01-03-2010 05:58 PM
Why long lasting bulbs go out of service quickly? art2670 Electrical 8 10-27-2009 09:10 AM
The long, dark road of renovation. Curb Feeler Introductions 1 02-03-2009 02:47 PM
Long range HVAC planning. dalesd HVAC 2 02-23-2006 01:37 PM
