Floor Tiles Not Sitting Perfectley Level - Flooring - DIY Chatroom Home Improvement Forum
Old 02-28-2011, 11:08 AM   #1
floor tiles not sitting perfectley level
i have leveled out my floor with SLC and put backer board over top, found center of my room and dry laid my tiles...now my problem is im having some tiles(13x13" tiles) not sit level or flat(which tells me the floor is not perfectly level or flat)...some seem to be out about 1/8" and rock from corner to corner(if that makes sense)...will this issue be solved with a thicker mortar bed in these spots? should i use a 3/8" trowel or stick with the 1/4"...many thanks for any help
ajones is offline   Reply With Quote
Old 02-28-2011, 04:24 PM   #2
1/8 of an inch shouldnt matter. level each tile with adjacent one by adding/removing mortar. use a 2' level.
acglobal is offline   Reply With Quote
Old 02-28-2011, 10:28 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 244
Jones,
An 1/8" hill over what length? The spec for substrate flatness when using basic tiles is: "Within 1/4" in 10 ft. and 1/16" in 12" of the required plane." Doesn't sound like you're ready for tiles yet.
Many people have trouble with SLC. They usually; Do not mix it right. Work too slow. Think it actually levels all by itself, cuz it's called "self-leveling". Do not have enough product on hand. Many times they need to do several pours.
You need to get a long straight edge and measure how out-of-plane it is. Let us know.
A 1/4x3/8x1/4 trowel is the basic one for your tiles. 1/4x1/4 is too small. You mentioned nothing about the subfloor, what is it?
Jaz
Leveling Kitchen Cabinets for Granite - how level?? vsheetz Kitchen & Bath Remodeling 13 03-02-2012 08:54 PM
Raising the level of concrete floor chandan.cogni Flooring 3 12-30-2010 07:37 AM
Kitchen Cabinet installation, upper cabinets not level BillyJack Kitchen & Bath Remodeling 0 06-30-2010 09:07 AM
level or not level toilet? ron0805 Plumbing 4 10-26-2009 05:16 PM
How do I get my ceiling level? Leah Frances Building & Construction 4 01-10-2009 02:12 PM
