Floor Tile Under Door Jam? - Flooring - DIY Chatroom Home Improvement Forum
Old 09-30-2012, 10:45 AM   #1
Question
Floor tile under door jam?
Our contractor did not seem to leave enough space underneath the do
Sill to put floor tiles and a subfloor. . He wants to butt tiles up to it but I think it is not a good idea to have a grout seam at the doorway. Is there a right or wrong way?
Kennjan2012 is offline   Reply With Quote
Old 09-30-2012, 01:38 PM   #2
Pro
JetSwet's Avatar
Rewards Points: 502
Can you post picture?
JetSwet is offline   Reply With Quote
Old 09-30-2012, 03:08 PM   #3
Rewards Points: 12,802
Tile always goes up to it not under it. And caulking is used, never grout anytime tile meets a differant material or makes a turn, (inside corner, outside corner) you use caulking.
Old 09-30-2012, 08:46 PM   #4
Rewards Points: 918
I wouldn't mind setting a door on tilebacker, especially if it were some waterproof tilebacker. Then tile up to it, and caulk the joint.
cleveman is offline   Reply With Quote
Old 09-30-2012, 08:56 PM   #5
DIY staff
Rewards Points: 7,174
Door jambs are 'under cut' using a 'jamb saw' or 'Under cutting' saw----
Tile goes under the door jambs----often the toe kick (riser) on a stair case is under cut----
The idea is to create the appearance of the floor under every thing -----Is this what you are talking about?
Installers without real flooring experience often 'tile in' the jambs---looks amateur and the wood will move--cracking that grout joint---
Then you have ugly,amateur work.
Old 09-30-2012, 09:10 PM   #6
Pro
JetSwet's Avatar
Rewards Points: 502
If there is a door saddle then the tile can meet at the door casing then trim molding will hide the cut end but if there is no door saddle then yes tile should be under the casing.
Old 09-30-2012, 09:13 PM   #7
DIY staff
Let's hope the OP comes back an gives us more information---
Old 09-30-2012, 09:24 PM   #8
Pro
JetSwet's Avatar
Rewards Points: 502
Yeah like a pic that I asked from the start lol
The Following User Says Thank You to JetSwet For This Useful Post:
oh'mike (10-01-2012)
Old 10-01-2012, 03:18 PM   #9
Rewards Points: 150
I'm no expert, but I think you already know the answer to your question. The right way would be to undercut the jamb and install tile under it. The wrong way would be what your contractor wants to do, instead.
What joecaption said wasn't wrong, though, either. If you encounter something that can't be undercut you can use a caulk that is color matched to your grout.
If that joint gets hidden under trim, like JetSwet said, it doesn't matter.
zakany is offline   Reply With Quote
