Old 08-04-2010, 03:07 PM   #1
Floor thickness problem with DELTA FL and PERGO at t molding???
Hi. Things were rolling along pretty good until I came to this issue...which I am sure has been solved by someone...
I have Delta FL installed on my basement concrete subfloor, and am about to install laminate flooring.
Between rooms I intend to install the t molding....but here is the issue:
The pergo t-molding, marketed under the name simple solutions, is for floors and subfloors of a combined thickness of up to 1/2 inch, and I am at 10/16. So, the t-mold will not snap into the track.
How has everyone resoved this?
Oxymoron is offline   Reply With Quote
Old 08-04-2010, 04:45 PM   #2
shim the track higher with a wooden strip
racebum is offline   Reply With Quote
Old 08-04-2010, 04:50 PM   #3
That was one of my solutions....what about installing it directly on top of the Delta FL....that has a high compression strength and should be fine?
Problem with Pergo woodinville guy Flooring 8 08-10-2005 06:46 PM
