-   -   Floor thickness problem with DELTA FL and PERGO at t molding??? (http://www.diychatroom.com/f5/floor-thickness-problem-delta-fl-pergo-t-molding-77917/)
Oxymoron 08-04-2010 03:07 PM
Hi. Things were rolling along pretty good until I came to this issue...which I am sure has been solved by someone...
I have Delta FL installed on my basement concrete subfloor, and am about to install laminate flooring.
Between rooms I intend to install the t molding....but here is the issue:
The pergo t-molding, marketed under the name simple solutions, is for floors and subfloors of a combined thickness of up to 1/2 inch, and I am at 10/16. So, the t-mold will not snap into the track.
How has everyone resoved this?
racebum 08-04-2010 04:45 PM
shim the track higher with a wooden strip
Oxymoron 08-04-2010 04:50 PM
That was one of my solutions....what about installing it directly on top of the Delta FL....that has a high compression strength and should be fine?
