Floor Supports & Subfloor Area - Flooring - DIY Chatroom Home Improvement Forum
Old 03-11-2011, 12:31 AM   #1
floor supports & subfloor area
what problems would result from the improper removal of floor supports and sub floor area in a bathroom ?
facka is offline   Reply With Quote
Old 03-11-2011, 06:03 AM   #2
woodman58's Avatar
At the minimum the floor will sag. At the worst with the weight of the tub with waterin it the floor could colapse. I would not do this.
woodman58 is offline   Reply With Quote
Old 03-11-2011, 04:10 PM   #3
Master of none
What??
As woodman said, not a good idea.
But::: There has to be a reason for the question!! Is this a hypothetical question?
I can not imagine why someone would want to do this!
handy andy is offline   Reply With Quote
Power goes out in back room & on by it's self!! happy_4_now Electrical 2 11-23-2010 06:09 PM
Skim coat over lathe & plaster that has been walpapered Nappanee Deb Remodeling 4 11-11-2010 10:45 AM
Drywall & metal studs. meow571 Drywall & Plaster 1 11-05-2010 05:59 PM
ice & water shield...has this code been reinforced in the state of ohio? rhonnie Roofing/Siding 1 11-05-2010 05:52 AM
Retaining wall 1ft. in width/100 ft. in length & 1 ft. in depth rcm Building & Construction 1 10-30-2010 10:55 PM
