Floor Is Still Squeeky - Flooring - DIY Chatroom Home Improvement Forum
Old 09-27-2011, 09:26 PM   #1
Floor is still squeeky
I am redoing our bathroom. The floor in there has always squeeked right in front of the vanity. I drove some screws in today along a couple of joists for about 2 feet. I am sure that I found the joists, but the floor still squeeks in that area. Could the subfloor be squeeking against the plywood? What are your suggestions and recommendations?
Smudgeboss is offline   Reply With Quote
Old 09-27-2011, 09:32 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 126
Is there a joint in the plywood? Many times the edges rub together.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 09-27-2011, 09:44 PM   #3
That makes sense. I don't think there is a joint, at least in the sub floor where I am working. I haven't pulled up the lino. planning on floating it and putting flooriing over top. I will do some more investigation thanks for the tip.
Fix Squeeky Subfloor... couchie Carpentry 2 01-09-2010 06:35 PM
laminate floating floor squeeky, is it normal? gagaliya Flooring 1 10-02-2009 05:27 AM
squeeky lanoleum floor debd Flooring 5 01-11-2009 04:16 PM
