Floor Stained Today - Flooring - DIY Chatroom Home Improvement Forum
Old 05-11-2013, 05:17 PM   #1
Rewards Points: 878
Floor stained today
Had my old wood floor sanded and stained today( expresso color). They applied the stain with towels. Is that correct ? They are coming back tomorrow to finish. Thanks
Edit/adder: just went up there and it does not look to bad but one area about 3'x3' is def a lot lighter than the entire floor . That is the area where he put the sample stains, after he sanded, so we could choose. My guess is that he sanded the stains off this making that area of sanding different than the rest. Anything that can be done about this ? Thanks
Mstrlucky74 is offline   Reply With Quote
Old 05-11-2013, 07:46 PM   #2
Rewards Points: 878
Here are pics. It also looks like he did not wipe the stain off all the way on the edges. I'm pissed
Floor stained today-photo-12-.jpg   Floor stained today-photo-13-.jpg   Floor stained today-photo-14-.jpg
Old 05-12-2013, 08:24 AM   #3
Rewards Points: 878
Anyone ???
Old 05-12-2013, 09:57 AM   #4
Rewards Points: 240
how about a pic from further back.
Fix'n it is offline   Reply With Quote
Old 05-13-2013, 09:49 AM   #5
Rewards Points: 264
It looks like the edges were not sanded evenly with the rest of the floor. If the finish has not been applied then it is possible to add a little more stain to the lighter areas. If the finish has been applied, then the only fix is to resand the floors.
Awoodfloorguy is offline   Reply With Quote
Old 05-13-2013, 10:53 AM   #6
Rewards Points: 878
Actually they fixed that area by sanding it. They did some type of steel wool thing to the entire floor and then polyed(matte finish) and I must say its looks soooo much better. They put 3 coats of poly... should I have them apply another coat or two? Thanks
Old 05-13-2013, 10:55 AM   #7
Rewards Points: 264
That's good news. 3 coatings is the standard, and what nearly all flooring companies use. So the floors should hold up very well with 3 coatings. However, more coatings never hurts..
The Following User Says Thank You to Awoodfloorguy For This Useful Post:
Mstrlucky74 (05-13-2013)
FYI Makita combo is 100 dollars off at HD today only forcedreno2012 Tools 0 05-03-2013 04:11 PM
Trane XE80 worked yesterday - won't come on today flounder HVAC 29 01-14-2012 11:26 PM
Hot water heater getting VERY hot all of a sudden today bgbrown125 General DIY Discussions 20 12-04-2011 06:04 PM
Baseboard Gap Options? Installing Floating Vinyl Flooring Today. Please Help. skeeter505 Flooring 1 09-17-2011 07:46 AM
Rough electrical inspection - passed today! THANKS!!! vsheetz Electrical 4 02-06-2009 10:42 PM
