Floor Staggering When There All The Same Length - Flooring - DIY Chatroom Home Improvement Forum
Old 04-11-2010, 12:12 PM   #1
Floor staggering when there all the same length
Hello,
I am about to start laying a bamboo floor however all of the pieces are the same length, I understand that you have to stagger and the suggestions I have been reading say that ends should be separated by about 6" but most flooring comes in random lengths. Now should I cut up a bunch of my boards and mix them in to acheive the stagger and if so what should I use to recut the end tongue/groove? I would think table saw but holding each board on end seems like a pain. Also, how random is random? should I measure and cut a couple different lengths 6", 1', 2' to go along with the "normal" 3 footers or should I not measure and literally randomly cut the boards?
Thank you,
Bryce
bwdane is offline   Reply With Quote
Old 04-11-2010, 12:20 PM   #2
Rewards Points: 266
Run your 1st course of flooring. The last piece in the run will more than liekly need to be cut. Use the remaining piece to start your next course. This way the end you cut will be the starting piece and not need a tongue/groove as it will be against the wall. Just continue going using the last piece you cut as the starting board for the next row.
Does that make sense? It's harder to put into words than it is to actually do
What have I done is offline   Reply With Quote
The Following User Says Thank You to What have I done For This Useful Post:
bwdane (04-11-2010)
Old 04-11-2010, 12:35 PM   #3
I'm pretty sure I get what your saying. I still have a couple days of acclimation and prep work to wrap my mind around everything though.
Bryce
Old 04-12-2010, 08:49 AM   #4
All the 3 footers should be in the 'field' the only cuts you should have are at the outside walls. As mentioned above what ever you cut off at one side, use the leftover piece to start you next course.
RTRCon is offline   Reply With Quote
Old 04-12-2010, 12:37 PM   #5
Thank you for the advice. I have one more question, for the cleats, do I have to use 1 1/2" or can I use 2"? I see the 2" alot but the 1 1/2" not so much.
Thank you,
Bryce
Old 04-15-2010, 11:53 AM   #6
You can use either.
If you have a 1/2" floor that you are installing on a 3/4" subfloor your total thickness would be 1 1/4". So 1 1/2" cleats would penetrate the subfloor by a little more than 1/4". Either one works but if you penetrate the subfloor too much you do risk damaging pvc, or pex, or electrical if they are run close to the subfloor.
Hope that helps.
bradfordw is offline   Reply With Quote
Old 04-15-2010, 01:02 PM   #7
All good advice so far but no one address your question on cutting.
You will want to use two tools. The table saw for your long cuts which you may need to make on the outside wall that runs paralell to the boards. And either a chopsaw, circular saw or jig saw to make your cross cuts.
anonymouscuban is offline   Reply With Quote
Hardwood Length...preference? JDeFuria Flooring 3 03-10-2009 05:38 PM
total effective length question drewhart HVAC 2 01-27-2009 08:46 PM
Maximum base board loop length Mike Warner HVAC 1 04-30-2008 11:48 PM
Pergola Unsupported Length wsuswim147 Building & Construction 2 04-08-2008 10:56 PM
Is it OK to tape by multiple pieces of tape on one length? KUIPORNG Remodeling 3 01-21-2007 12:17 PM
