Old 12-02-2006, 08:12 PM   #1
Floor spacers when installing laminate floor
I am installing locking laminate flooring in my daughter's bedroom. The directions say to use 1/4 inch spacers around perimeter of wall. The problem is my drywall doesn't come down far enough so that the laminate flooring actually fits under the drywall. So how do I use spacers? I can't put them in under the drywall against the stud, because I won't be able to get them back out.
Suggestions? Thanks
flybynite is offline   Reply With Quote
Old 12-02-2006, 08:30 PM   #2
HarryHarley
HarryHarley's Avatar
The 1/4 space would be in front of the drywall. This compensates for the expansion of the wood. The molding will cover it. I assume you have floor molding? If I read your question right.
HarryHarley is offline   Reply With Quote
Old 12-02-2006, 08:46 PM   #3
"The 1/4 space would be in front of the drywall"
Thats fine EXCEPT, my drywall doesn't come down far enough. The laminate flooring will slide right under the drywall and would butt up against the floor stud. I can't put a spacer against the stud because then I won't have enough room to get it back out. The spacer would end up under the drywall and behind the laminate flooring with no way to retrieve it.
Old 12-02-2006, 10:29 PM   #4
remodeling pro
Since you can so easily slip the flooring under the dw, I interpret that to mean that there is no baseboards in place currently, so get some 1/4 " laun plywood or masonite and rip it into 3 to 4" strips, then cross cut into 3 to 4' pieces. Lay the pieces at the base of the walls ,on edge, a few feet apart and tack then in place through the dw, low enough so that the nail holes will be covered by the baseboard. This will act as stops for the first rows of flooring. Remove when the floor is laid and install the baseboard, which will cover any nail holes in the dw.
troubleseeker is offline   Reply With Quote
Old 12-04-2006, 10:24 PM   #5
Floorwizard's Avatar
that's the way to do it.
no need to try to stay 1/4 away from the stud.
just need to install something on the drywall to come down so you can push the lam up to it for the first rows.
it doesn't matter if the lam will actually be 1/2 or so away from the stud.
that just gives it MORE expansion space
good luck
Floorwizard is offline   Reply With Quote
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
Installing Laminate Flooring over Wood Laminate Floor bantammom Flooring 7 05-27-2011 04:34 PM
Installing Laminate over uneven pine plank floor? tomzpc Flooring 6 04-16-2008 09:07 AM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 10:23 PM
Horizon Laminate Floor from China Kelvestto Flooring 3 09-20-2006 12:19 AM
