Floor Severely Sloped (3"). What Are Our Options? - Flooring - DIY Chatroom Home Improvement Forum
Old 06-26-2011, 12:25 AM   #1
Rewards Points: 101
Floor severely sloped (3"). What are our options?
We just purchased a self leveling line laser and were shocked to see how sloped our living room floor is. This will impose a great problem because we plan to put down laminate flooring in the living room, the wood room, and the kitchen (see the diagram below). The laminate floor installation instruction has this requirement on levelness: "Make sure the subfloor is flat. Any unevenness greater than 2mm (1/16") over the length of 1 meter (40") must be smoothed out.". Ours is 10/16" over 40"! Argh!
The rest of the house is not too bad though. I don't know what happened to the living room. Maybe it was built (as an addition to the old cabin) crooked. But if we could avoid it, we will not mess with the foundation. Now, how do we address this sloping floor in the living room (3" over 186" span) just for proper installations of flooring and cabinets?
In my very naive view, we lay plywood sheets across the room, with a gradual reduction in the number of layers from left side to the right. Use leveling compound to even out the step downs. This way, we achieve a level floor in the living room. We will make a 3" step down from the living room into the wood room and the kitchen (along the dotted blue line).
What would you do?
mudworm is offline   Reply With Quote
Old 06-26-2011, 01:14 AM   #2
NACE Coating Inspector
mustangmike3789's Avatar
is it 10/16 or 5/8, this may be the determining factor in the equation. what kind of laminate are you using?
mustangmike3789 is offline   Reply With Quote
Old 06-26-2011, 05:55 AM   #3
woodman58's Avatar
The way I understand this is that the floor is sloped from one side to the other. If this is true and the floor is flat but just sloped then there is no problem. Lay a straight board as long as you have (at least 8 feet) on edge across the floor in several spots. If there is not any dips or high spots between the end of the board then you are good to go. Your floor does not have to be level, just flat.
woodman58 is offline   Reply With Quote
Old 06-26-2011, 06:19 AM   #4
Rewards Points: 200
I stretch a cpt string 10' and look for valleys with a taper gauge . Being that the guidelines are 3/16 in 10 ' pull it tight . duct tape the ends . this will show you the contour of the floor . Woodman is right . it don't have to be level , it has to be flat .
Floor Doc is offline   Reply With Quote
Old 06-26-2011, 09:08 AM   #5
Rewards Points: 1,016
If the out of level has not been a problem heretofore and the floor is flat, no problem.
____________
Vince
Old 06-26-2011, 10:23 AM   #6
Civil Engineer
Rewards Points: 4,764
As previous posters have noted, flat and level are totally different issues. Assuming you accurately measured a 3 inch deflection delta in elevation over 15 feet, you may want to investigate why there is such a large difference in elevation. This could indicate settlement of the supports towards the center of the house. It is unlikely it was built that way, even the worst carpenter can get a floor more level than that during initial construction.
The largest issue would be the potential for continuing settlement of the foundation. This is difficult to determine, and usually requires you to hire an engineer or specialized contractor to investigate the foundation and determine if the settlement is continuing, or ended some time ago.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
Floor Doc (06-26-2011)
Old 06-26-2011, 10:54 AM   #7
Rewards Points: 101
Thanks all to your replies. After I posted, the realization did come to me that the laminate flooring mfr shouldn't care if the whole floor is sloped as long as it's even. The floor appears to be fairly even, but I will do some exercises (straight board or string) to confirm. As for the cause? It puzzles me. The rest of the house appears to be pretty flat, so if anything, I think the uphill side may just have risen. But I don't see big gaps. Don't know and will not lose sleep over it.
Old 06-26-2011, 11:12 AM   #8
Rewards Points: 200
Manufacture , and NWFA installation guidelines state the floor must be within 1/8" in 6' or 3/16" in 10' for flatness . Good luck with your new floor .
Basement floor options? jfall Flooring 1 02-25-2011 01:10 PM
Need HELP swapping a Vision pro 8320u1008 to an IAQ one N01B4ME HVAC 161 01-10-2011 02:30 PM
Finishing basement - concrete walls options droyer Building & Construction 1 01-13-2010 06:27 PM
Options for Cold Basement Concrete Floor? jefferis Flooring 16 12-09-2009 12:23 PM
Garage/shop floor options philS Flooring 5 05-06-2009 06:10 AM
