Old 09-04-2006, 11:15 PM   #1
Floor Prep for Tile Floor
We are getting tile floors installed next week. We decided to save the money and remove the old tile on our own, the question is, how smooth does the floor need to be for the new install? We spent all weekend scraping morter out. Does the floor need to be perfectly smooth with every remnant of morter removed, or is there a little give in how much can be left? We do not have any raised edges left, just some morter remaining, but when we take up that morter, we are taking up the cement slab underneath. Thanks for any advice!
Erin
etopf is offline   Reply With Quote
Old 09-05-2006, 07:48 AM   #2
Master Craftsman
Big Dave's Avatar
In my opinion it does not need to be removed completely but does need to be ground or scraped flat so there is no chance of it causing a tile to wobble. It also will give you a flatter looking floor.
Do one thing at a time, do it well, then move on.
Big Dave is offline   Reply With Quote
Old 09-05-2006, 09:32 PM   #3
Floorwizard's Avatar
any high or low will affect the new tile badley.
It really would be wise to remove as much as possible. Even if it means leveling afterwords.
plus you will need an anti fracture membrane before the tile goes down.
Floorwizard is offline   Reply With Quote
Problem with stain on Laminate Floor Lilypebbles Flooring 4 11-04-2009 05:06 PM
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 08:57 PM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 10:23 PM
Floor joist lower than others drhowarddrfine Flooring 2 04-26-2006 04:25 PM
Help wih floor extremer1519 Flooring 1 12-27-2005 07:33 PM
