Floor Prep For Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 03-03-2007, 12:52 PM   #1
Floor prep for tile
Hi
Wondering what needs to be done in order to lay ceramic or porcelain tile on a floor?
The floor is; 2x10's on 12" center, no vibration
3/4" sheathing on floor joists
3/8" plywood on sheathing
plywood is screwed down with heads countersunk
Thank You
shimp is offline   Reply With Quote
Old 03-03-2007, 01:12 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
I am NOT a pro tile man, but you need a layer of cement board screwed to the flooring to lay tile on. Do not put it directly on wood of any kind.
I would go with ceramic. Porcelain cracks and scratches much more easily.
Mike
Mike Swearingen is offline   Reply With Quote
Old 03-03-2007, 08:46 PM   #3
Mike
You need either a cementboard or a membrane such as Ditra over the plywood, if using a cementboard, it get's set in unmodified thinset and screwed down, follow the instructions.
As for the tile, Porcelain IS ceramic and the toughest and most durable flooring tile there is, would love to know who told you the info above, Porcelain cracks and scratches more easily??, I doubt that, use any ceramic with a PEI rateing of 4 or 5, 5 being the better one.
R&D Tile is offline   Reply With Quote
Old 03-04-2007, 01:06 PM   #4
ok, thanks for help guys..
few more questions->
this is not in a room that will be bath or shower, kinda a den.
what is ditra, and will it be needed if no moisture?
thanks
Old 03-04-2007, 01:17 PM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
thanks
DITRA - link below:
http://www.schluter.com/english/prod...601-ditra.html
- Build Well -
Old 03-04-2007, 02:56 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 288
Although there are lots of tiles installed over plywood, it is never a good idea. If you want it to last you need a tile backer board or a product such as Ditra. Otherwise something like this could happen to you. http://www.ontariotile.com/cgi-bin/u...c;f=1;t=001341
What you just read happens all the time.
Jaz
