Old 11-06-2008, 11:33 AM   #1
Floor over concrete garage floor
Single car garage with concrete--slight fall (can live with that); will have Pergo-type flooring when finished. Would like to add some form of insulation between the concrete and the 'Pergo'. 1. Is there some form of insulation that can be put on the concrete and the 'Pergo' floated over it? If not, 2. Is building a 'frame' base on the concrete and putting on plywood and then the 'Pergo' (putting in insulation between the framing boards) the only other solution? 3. What type of insulation could I use, then, which would also have the vapor barrier?
Luella is offline   Reply With Quote
Old 11-06-2008, 12:57 PM   #2
Floorwizard's Avatar
A vapor barrier pad for lam will work just fine. The floor can be unlevel, but MUST be flat.
Please do not drive the car on it
Floorwizard is offline   Reply With Quote
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
Removing Concrete Ridge and Ground Protection on Ground Floor RayIII Building & Construction 1 10-09-2008 03:36 PM
Blacktop on Garage Floor?? terrypearson Flooring 3 08-06-2007 08:05 AM
Garage Concrete Ledge for Door Replacement orangewhip Building & Construction 7 05-22-2006 08:09 PM
