Floor Over 24" O.c. Truss Joists - Flooring - Page 3 - DIY Chatroom Home Improvement Forum
Old 10-15-2011, 10:33 PM   #31
OK, thee was an email address on my paperwork for the structureal engineer and he wrote me back with a new ph number to call back mon, so I hope to find out from him, he was very helpfull when I was building
joebeadg is offline   Reply With Quote
Old 10-24-2011, 08:20 PM   #32
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,110
24" o.c is pathetic for a floor joist layout. 19 3/16" o.c is the max and this is only for engineered joists. for a smaller engineered joist 16" o.c is common for renovation situations involving additions . for regular lumber 12 o.c is pretty standard for most of the homes i have built .
the only time i do 24 " o.c is for roof trusses. take note that the bottom chord of a roof truss isnt rated to use as a floor. if you want a section of the attic as livable space or as a small section of floor space spec this so the engineer can allow for it when designing the trusses
woodworkbykirk is offline   Reply With Quote
Old 11-09-2011, 08:27 AM   #33
OK, finaly found out about my trusses. The strctural emg said the trusses are designed for all residential rooms design loads. Living rms, bedrms, kitchens and baths. He said to use threequarter T@G plywood, and screw and glue it. Now I know some of you thought these were not up to the job, but this is what he's saying, and he's a legit guy. Now, I've never heard of any, but is there a lighter weight sheetrock I could use to keep weight to a minimum?
Sistering Joists and Adding a Beam Mikeman Building & Construction 6 09-30-2011 08:11 PM
Bubba's been here. Repairing sagging rim/floor joists. MattFels Building & Construction 7 02-09-2011 05:28 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 08:00 AM
Floor Joists of different sizes HooKooDooKu Drywall & Plaster 7 02-04-2010 05:43 PM
Sister or Replace Floor Joists brando1118 Carpentry 25 10-26-2008 08:43 PM
